LI150
Sep 09, 2013Aspirant
Single blinking green light HDD light on Duo? What's wrong?
I've tried searching the forum for help but can't find what I'm looking for.... Can anyone tell me what's wrong with my Readynas Duo? I have one green flashing HDD light flashing at a constant spee...
Sep 10, 2013Guru - Experienced User
I'd suggest running manufacture diags on the drives (seatools for seagate, lifeguard for western digital) as a good next step. It could be the chassis (as you are thinking), but I still think it is worth testing the drives.
I would also backup the data with diskinternal's linux reader to a PC (which requires putting drive 1 into the PC either directly or with a usb/esata enclosure).
