LI150
Sep 09, 2013Aspirant
Single blinking green light HDD light on Duo? What's wrong?
I've tried searching the forum for help but can't find what I'm looking for.... Can anyone tell me what's wrong with my Readynas Duo? I have one green flashing HDD light flashing at a constant spee...
LI150
Sep 16, 2013Aspirant
StephenB wrote: The RN102 is Netgear's current 2-bay model. It is faster than the duo you have now, and handles bigger disks. If you were basically satisfied with the duo, it is worth a look.
The RN312 is faster still (but is more expensive than the RN102).
Both of these run OS6, which is the going-forward software platform for ReadyNAS.
Thanks Stephen. If I buy the disk free 102 or 312 can I just bung the drives from the duo straight in?
