LI150
Sep 09, 2013Aspirant
Single blinking green light HDD light on Duo? What's wrong?
I've tried searching the forum for help but can't find what I'm looking for.... Can anyone tell me what's wrong with my Readynas Duo? I have one green flashing HDD light flashing at a constant spee...
Sep 17, 2013Guru - Experienced User
You can't migrate your data that way - the disk format is different, so the new NAS would need to wipe it.
The drives might work, but If they are not on the HCL for the new NAS, Netgear can/will deny support for disk-related problems.
