hiddenhills
Jul 31, 2014Aspirant
Slow ReadyNAS Duo access with iMac
Just purchased a new iMac and installed Word 2011 for MAC. The iMac was purchased to replace an aging Dell PC. In setting up a default folder in Word that points back to the existing folder on m...
hiddenhills
Thanks for the reply. Yes, the Dell was running Win XP.
Both AFP and SMB are enabled (green lights on) when I run ReadyNAS setup under RAIDar. I'm on a wired home network using a Netgear router.
Folders in ReadyNAS that do not contain many files are more quickly accessed. I have one folder with a large amount of Word and PDF documents and that folder takes minutes to see the files. This, with Word for MAC or under the MAC FileFinder.
Paul
Paul
