riplatt
Aug 03, 2012Aspirant
[Solved] ssh stopped working (connection refused)
I installed the photo II add-on and now I can’t ssh into my readyNAS Some details ReadyNAS pro Firmware 4.2.21 Other add-on all still running -Couchpotato -Headphones -Php5 -Python 2.7 -Sabn...
mdgm-ntgr
Aug 04, 2012NETGEAR Employee Retired
You probably better contact NetGear support (http://www.readynas.com/support). They might be able to tell from the logs what has happened and suggest a fix or remotely login and investigate.
