e5chan
May 24, 2013Follower
Stuck on boot checking file system
Hi, This is my first post and first time using this forum, so bear with me if this has already been answered since I'm still new with navigating this forum. Recently my ReadyNAS NV+ was hung and n...
May 24, 2013Guru - Experienced User
OS reinstall instructions are in the hardware manual.
First though, you should confirm your model (V1 or V2). The labels are misleading, so use this guide: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Note you can also bypass the file system check during reboot. That might be worth doing first. If it succeeds, I suggest that you backup your data before doing anything else. If you don't have enough disk capacity to make a full backup, at least back up what you can.
