apankrat3
Oct 04, 2011Aspirant
Stuck trying to do a factory reset on NV
Hi, I am trying to reset my NV box by following instructions (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) and I am not seeing the described behavior. Here's what I do: 1. I...
ReadySECURE
Oct 08, 2011Apprentice
I'm glad you were able to figure out your issue. In the future you can always contact support via email for any questions or issues you may have. There are limitations as to what support handles/supports but anything like this would have been supported.
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
