ChunkySocks
Sep 04, 2025Guide
sudo: unable to write to /var/lib/sudo/ts/admin: No space left on device
I've SSHed into my NAS and got this message:
This has all seemed to start after doing some tinkering with the Logitech Media Server which I now suspect, could have been installed incorrectly in the wrong location.
If I run df -h the result is:
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.7G 4.0K 100% /
tmpfs 491M 4.0K 491M 1% /dev/shm
tmpfs 491M 3.7M 487M 1% /run
tmpfs 246M 1.4M 244M 1% /run/lock
tmpfs 491M 0 491M 0% /sys/fs/cgroup
/dev/md127 2.8T 1.9T 855G 70% /data
/dev/md127 2.8T 1.9T 855G 70% /home
/dev/md127 2.8T 1.9T 855G 70% /apps
If I attempt to logon via the ReadyNAS GUI I continually get asked for the user and password, entering admin and then password just loops back around to another dialogue box with the same request.
Please reassure me that I haven't completely borked the ReadyNAS OS! 😳
- SandsharkSensei
I have installed a couple of packages that aren't Readynas specific that expect to be installed in the root partition, and the following is what I did. As long as at least most of the files are installed in a separate directory and, more importantly, all data is placed within that directory or another application-specific one, this should work for you. Note that in specific commands, I've used two spaces as a delimiter to make it clear there is a space. They aren't necessary, but Linux doesn't care how many spaces you use.
Start by doing a normal install in the OS partition. Note the name(s) of the new directories created. I'm using plural here, but it's often just one. You can run it to make sure it works, but if it creates a database or other large file(s), it's best to not let it do that. Some time ago, I copied the following command from a Reddit post as a way of finding the newest directory: find . -type d -printf '%T@ %p\n' | sort -nr | head -n 1. Note that the final 1 is the number of directories to list, so you may want to increase it.
Create a mirror (copy all files and folders) of those directories in /apps. While /apps appears to be at root, it's actually a mountpoint for /data/apps (assuming your main data volume is data). If there are multiple directories involved, you may want to make your mirrors sub-directories of a main one you create in /apps.
Next, rename the directories in the OS partition and then create symlinks in their place using the original names.
Now, run the program. If it works, you're almost done. If it doesn't, go back and see what you missed. Once it's running as expected, you can delete the renamed directories and you are done.
If the original install has symlinks within it, then there is more work to do changing them, but that will be too application-specific for me to cover here.
Once set up, this will typically also allow you to install updates without having to re-do all this.
So, in a hypothetical install with a single directory (with or without subdirectories):
Normal install creates /usr/local/myapp.
You create /apps/myapp and copy all contents of /usr/local/myapp there (all in this one command): cp -r /usr/local/myapp /apps/myapp.
You rename /usr/local/myapp: mv /usr/local/myapp /usr/local/myapp.old.
You create a symlink: ln -s /apps/myapp /usr/local/myapp.
Test the program.
If all is well, delete the original installation: rm -r /usr/local/myapp.old.
Since you are messing around in the OS partition, double-check all commands before executing. Writing them in a text file and then pasting from that is a good way to do that. Plus, you can save the text file for use as a guide for the next install.
I suspect you don't need quite as much detail as I've given, but others who need it may read and try to follow this.
Let me just say that I am extremely appreciative and grateful for the time, thought and engagment that anyone offers on a thread like mine, even if my choices and actions may be a source of frustration to those with vastly more experience in using the CLI and delving deep into OSes.
Know that my use of LLMs like DeepSeek, ChatGPT etc, is, in the main, to ask basic questions about commands that do simple things to avoid clogging up a thread like this and exhausting the patience of those for whom it is second nature, whether be it because it's their job or a long-time computer hobbyist & tinkerer. I am mindful that the informal chatty nature of these LLMs whilst seductive, can offer poor or just plain incorrect 'advice' for the more complicated questions and ideally, s/b run by anyone who is willing and able to read over it in forums like this.
StephenB wrote:
This is normal - did you remove files to bring it down to this level?
Yes. I installed ncdu and found that Syncthing (installed incorrectly in this location to begin with) was taking up 2+GB space, so deleted it all as I'll install it again in a different partition, setup and run an initial sync again, no big deal apart from the time a first sync takes.
Before that, I deleted everything from /var/lib/squeezeboxserver/cache, which was recommended on a help thread I started within the Lyrion (renamed from Logitech) support forums but that only reclaimed a few hundred MBs.
StephenB wrote:
Instead run this (using ssh on the NAS, logged in as root) :
Thanks for the suggestion. I ran it, despite the ominous warning about how long it may take, it took less than a minute, no error messages and the output was:
WARNING: Full balance without filters requested. This operation is very intense and takes potentially very long. It is recommended to use the balance filters to narrow down the scope of balance. Use 'btrfs balance start --full-balance' option to skip this warning. The operation will start in 10 seconds. Use Ctrl-C to stop it. 10 9 8 7 6 5 4 3 2 1 Starting balance without any filters. Done, had to relocate 11 out of 11 chunksStephenB wrote:
Which is what I see on bothe new discussions and replies. What format options are you looking for????
I just had more options for the initial post that started this thread and expected to be offered the same options for any subsequent post.
I think I was mainly after the Preformatted option as part of the Paragraph dropdown but you don't this for subsequent replies. Anyway, a minor issue that can be worked around, a little jarring but no biggie.
Sandshark wrote:
If the files are corrupted, then a BTRFS repair isn't going to fix them, but an OS re-install might. But your OS partition is far too full to try that now.
OK, I have taken the advice of StephenB​ on board and as I mentioned at the top of this post, have deleted a bunch of files from the LMS cache sub-folder and deleted Syncthing entirely as I shouldn't have installed it on the root partition in the first place (and ignored the nagging warning messages that would pop up sometimes when I logged into the Syncthing GUI, yup my bad).
At time of writing, running df -h gives:
/dev/md0 4.0G 1.4G 2.5G 35% /Sandshark wrote:
You need to run btrfs filesystem df /.
OK, that gives:
Data, single: total=1.62GiB, used=1.25GiB System, DUP: total=32.00MiB, used=16.00KiB Metadata, DUP: total=128.00MiB, used=20.59MiB GlobalReserve, single: total=16.00MiB, used=0.00BAre you able to say if that looks ok? Hopefully it does.
I've slightly messed up my LMS, so I'm going to head over to the thread I've posted there because although the LMS rescanned my music library, all the meta data associated with the files disappeared, probably with the deletion of the contents of the cache directory but I'm hoping that the data I need is still within the files in the prefs directory.
I think I need to move the LMS installation from the OS partition too and that could tie in with installing a new stable version of the software that has recently been released (9.0.2) so I could install the LMS correctly in a different location and 🤞 restore all the missing meta data and ratings, assuming I still have the necessary files.
Do you recommend any further actions?
Appreciate your time and replies.- StephenBGuru - Experienced User
ChunkySocks wrote:
OK, that gives:
Are you able to say if that looks ok? Hopefully it does.That looks ok.
StephenB wrote:
That looks ok.
Thanks.
Thankfully I've also managed to restore a backup I made of the persist.db which contained all the ratings, play counts and other meta data so that's a major relief. Relief that I made the backup in the first place plus at the right time so it contained all the UUIDs.
Remaining steps are to:
- install the more recent release in a location outside of the OS partition
- restore the files that contain the track ratings, play counts etc. there
- make sure it's working
- re-install Syncthing, again, in a location outside of the OS partition
- get that up and running then happy days!
Thanks again both for all your posts and help.
- SandsharkSensei
I fail to see anything that indicates there is a BTRFS error on /dev/md0. It's just too full. As StephenB​ has been telling you, you need to find and delete some of the files that are there, most likely the result of LMS. If the files are corrupted, then a BTRFS repair isn't going to fix them, but an OS re-install might. But your OS partition is far too full to try that now.
Standard Linux df on a BTRFS file system is unreliable. You need to run btrfs filesystem df /. In particular, you need to pay attention to both the data and metadata usage. As StephenB​ also told you, you may need to run a balance on the OS partition to reclaim metadata.
I've never used LLM, but it's clearly designed for use on a standard BTRFS-based Linux installation. I think you should stop listening to it so much. Booting to a USB system to repair the ReadyNAS file system is really a bad idea. You should be booting to tech support mode, but I see nothing that indicates you need to do that at this time.
So it looks like I've corrupted the filesystem on the system partition.
Is this repairable?
btrfs fi show /dev/md0gives
Label: '758ad464:root' uuid: f08a0f90-adfd-47e1-a519-189247895ced Total devices 1 FS bytes used 1.14GiB devid 1 size 4.00GiB used 3.67GiB path /dev/md0Now if I input
df -hthe results are
Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1.3G 2.4G 35% / tmpfs 491M 4.0K 491M 1% /dev/shm tmpfs 491M 3.7M 487M 1% /run tmpfs 246M 4.0M 242M 2% /run/lock tmpfs 491M 0 491M 0% /sys/fs/cgroup /dev/md127 2.8T 1.5T 1.4T 52% /data /dev/md127 2.8T 1.5T 1.4T 52% /apps /dev/md127 2.8T 1.5T 1.4T 52% /homeso there's more space on /dev/md0 but the LLM is now advising that I run
btrfs check --repairfrom Ubuntu that's installed on a USB drive but is it possible to amend the boot order in the BIOS using SSH?
Thanks for any assistance.
Don't. The --repair is quite risky, so it is good to avoid doing if you have other options. And as Sandshark​ says, there is no evidence that the file system needs repair.
btrfs balance //If you get an error on the balance, please post the details.
ChunkySocks wrote:
I only see ...
- SandsharkSensei
Root isn't "/root", it's just "/". cd /
Thanks for replying Stephen.
To update, I did a reboot from ssh, logged back in, changed to root and didn't get the error.
Running df -h again gets:
/dev/md0 4.0G 3.1G 585M 85% /
so a small amount of space reclaimed...Unrelated aside: why don't I have the option to preformat text like in my original post?
so a small amount of space reclaimed...Still dangerously full, so you should do more to reclaim it.
There are some things I like about the new forum software, but there are some aspects that are steps back. You can post feedback here: We Want Your Feedback | NETGEAR Communities But don't expect quick action.
I see the same formatting options in the toolbar in replies as I see in new discussion threads. So I'm not sure what you mean.
I wish they'd put back underlines, and sometimes the strikethroughs were helpful. And there are inconsistencies - PMs have fewer options than forum posts.
FWIW, my impression is that the performance is a bit worse than the old forum.
I only see 👇
I'm using the Deepseek LLM for some pointers (with a bit of wariness that it advises something totally wrong) and may have got somewhere.
Am logged in as root, gone to base directory and ran:
du -sh * | sort -hr
which gave:
du: cannot access 'proc/2723/task/6523/fd/109': No such file or directory du: cannot access 'proc/6903/task/6903/fd/3': No such file or directory du: cannot access 'proc/6903/task/6903/fdinfo/3': No such file or directory du: cannot access 'proc/6903/fd/3': No such file or directory du: cannot access 'proc/6903/fdinfo/3': No such file or directory 1.5T data 4.0G apps 2.2G root 470M usr 441M var 33M lib 30M frontview 11M sbin 11M etc 6.6M bin 5.4M run 4.7M opt 8.0K dev 4.0K tmp 4.0K lib64 0 sys 0 srv 0 proc 0 mnt 0 media 0 bootthen I wanted to drill down into the root directory and see what was taking up 2.2G of space in there but even though I was a root user, cd /root didn't do anything.
then
mount | grep " / "
gave
/dev/md0 on / type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/)
which Deepseek says the nospace_cache is a red flag for Btrfs filesystem corruption and that needs repairing, ideally from a bootable USB drive though there is a less reliable method of using the repair tool on the mounted filesystem.
As this seems to be related between trying to optimise my LMS setup but now seems to involve fixing something I've broken within the ReadyNAS OS, I've initially posted there in this thread:
Error on 'Clear library and rescan everything' > database or disk is full
and I'll be bouncing between there and here.
There's space on the NAS itself, over 800GB but it seems I've filled up the OS partition.
Correct.
ChunkySocks wrote:
Thanks for any assistance or guidance on how to resolve this.
You have to remove the files that filled it.
That can be done with ssh. Or it can be done by doing a factory reset - which of course requires a full backup, since it reformats the disks. It also would require reinstalling any apps - which can be a problem now that the Netgear repos have been taken down.
In your case, I'd start by manually uninstalling the Logitech Media Server. If you have an x86 NAS, then the OS partition is BTRFS (unless you migrated the disks from an Arm NAS). If that is the case, you should also try a balance from ssh after you remove the Logitech server.
In general, you want apps (and app data) stored on the data volume. One way to do that is to create an LMS folder manually in /apps, and then move OS folders for the app to that folder. Create soft links that point to the new locations.
(Note /apps is a mount point for /data/.apps)
