steveoelliott
Oct 07, 2013Luminary
System Hang Due to Backup Failure
Hi all, (#22039954 Raised) Today my ReadynasPRO 6 hung upon accidently starting a backup job and the drive being removed from the system. The system was hung hard and had to be hard shutdown (he...
steveoelliott
Thanks... Thats interesting. I'll raise a case anyhow. Obviously the solution is to not have the device disconnected on the first place but still it shouldn't happen.
It is a bug and should be addressed!
How do you actually disconnect one of these using the backup button? The old NV+ used to flash the disk lights when you could remove the disk, what does this unit do? I personally have only disconnected from Frontview.
