Craig_X
Jun 14, 2017Aspirant
System volume root's usage is 100% and /dev/md0 is using all 4G
Running 6.7.4 firmware. No applications installed. Connected USB drive and started a backup which did start correctly, but ultimately failed (though after examining the share it does appear that th...
- Jun 15, 2017
Craig_X wrote:
root@PRANAS-TNG:/# find / -xdev -type f -size +100M
/var/cores/core-readynasd
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/pvranchad_book.xml
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/PVRanchAD (1).xml
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/pvranchad_pax.xml
/media/USB_HDD_11/Pat/Aerial Footage - Max/Princeville Ranch Cut 3.mp4You can delete /var/cores/core-readynasd for sure.
You can also remount the root file system, so you can search through it without mount points from muddying the water.
To do this you enter
mount --bind / /mnt
find /mnt -xdev -type f -size +100M...
In addition to searching, etc you also would delete files directly from /mnt.
Maybe also try
mount | grep -i USB_HDD_11
That should let you know if USB_HDD_11 is a mount point or just a folder. It you don't see it in the output of the above command, then it is just a folder. You can delete it's contents if you wish, but perhaps keep the folder itself.
When done, you unmount with umount /mnt
Jun 14, 2017Guru - Experienced User
Usually there's one or two huge files that need to be cleared. Have you searched for those via ssh?
- Craig_XJun 14, 2017Aspirant
Not really sure how to go about searching. Would the files be under /dev/md0?
- StephenBJun 14, 2017Guru - Experienced User
They are on /dev/md0, but /dev/md0 is the disk partition, and is not part of the path.
Try
cd //
du -hsx * | sort -rh | head -10
That will show you the biggest folders, If (for example) the problem seems to be in /var, you can then
cd var
That usually gets you to the problem area pretty quickly.
