Craig_X
Jun 14, 2017Aspirant
System volume root's usage is 100% and /dev/md0 is using all 4G
Running 6.7.4 firmware. No applications installed. Connected USB drive and started a backup which did start correctly, but ultimately failed (though after examining the share it does appear that th...
- Jun 15, 2017
Craig_X wrote:
root@PRANAS-TNG:/# find / -xdev -type f -size +100M
/var/cores/core-readynasd
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/pvranchad_book.xml
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/PVRanchAD (1).xml
/media/USB_HDD_11/Pat/ATCO/ATCO DATA/pvranchad_pax.xml
/media/USB_HDD_11/Pat/Aerial Footage - Max/Princeville Ranch Cut 3.mp4You can delete /var/cores/core-readynasd for sure.
You can also remount the root file system, so you can search through it without mount points from muddying the water.
To do this you enter
mount --bind / /mnt
find /mnt -xdev -type f -size +100M...
In addition to searching, etc you also would delete files directly from /mnt.
Maybe also try
mount | grep -i USB_HDD_11
That should let you know if USB_HDD_11 is a mount point or just a folder. It you don't see it in the output of the above command, then it is just a folder. You can delete it's contents if you wish, but perhaps keep the folder itself.
When done, you unmount with umount /mnt
Craig_X
Jun 15, 2017Aspirant
Using the command you provided led me to two directories... USB_HDD_12 and USB_HDD_11. Those seems to be USB attached hard drives. But here's the thing... There is only one USB attached hard drive, and exploring the shares it show as USB_HDD_12. I wouldn't think this would be a part of the root file system, but I'm not sure how to tell. Furthermore, it shows 59G in USB_HDD_12, which wouldn't fit in the 4G md0. USB_HDD_11, however, shows 3.4G, which would be just enough to fill up md0. Also, I came across another command which is supposed to show only large files in a specific directory/drive/patition/whatever (I don't really understand). This command is:
This command showed the large files in USB_HDD_11, but not those in USB_HDD-12. So I'm guessing I need to delete/remove the files in USB-HDD_11.
Here is the output...
What do you think?
Jun 15, 2017Guru - Experienced User
mount --bind / /mnt
Maybe also try
- Craig_XJun 15, 2017Aspirant
mount | grep -i USB_HDD_11 didn't produce any output, so I guess USB_HDD_11 is a folder. There was a lot in it, and I couldn't figure out an easy way to delete all the contents without deleting the folder, so I deleted the entire folder. Now my usage is down to 16%. Everything seems to be working, so I'm inclined to say that fixed the problem. I guess I'll know after another day goes by and I can examine the logs.
I also unplugged the external USB drive. When I did that, the folder USB_HDD_12 disappeared. So I'm thinking the NAS creates a folder whenever a USB drive is attached, but it doesn't (or shouldn't) write the data to the root volume. This is consisent with the fact that I looked in the USB_HDD_12 folder in the root and it was empty even though I could browse the share and see that there was data on the external drive.
I'll come back and mark as solved if everything is still working tomorrow.
Thanks for the help.
- mdgm-ntgrJun 15, 2017NETGEAR Employee Retired
In future before deleting a core file I'd check the date it was created/modified doing e.g.
# ls -la /var/cores
If the date is recent then it may be useful for troubleshooting an issue in which case you should copy it to the data volume before deleting it if you need to delete it.
If the core file is very old then it's probably not very useful at all anymore.
