  • i am getting a xeon x3230 to try on my pro 6
    read somewhere in this forum that it is workable
    • cpu8088's avatar
      cpu8088
      Virtuoso
      put in x3230 for few days. does not seem noticeable difference from original pentium d. perhaps faster for transcoding but i dont use.
      now swapped that with a core2duo E7500 3.0GHz. ui pop up faster and cpu runs cool.
  • The X3230 is the Q6600 in the Xeon branded world. And yes, it works :-)
    • cpu8088's avatar
      cpu8088
      Virtuoso
      q6600 runs at 2.4
      x3230 runs at 2.66
      xeon has different instructions more suitable for servers
      • walshlink's avatar
        walshlink
        Luminary
        I am running a Xeon X3230 on my RDP Pro 6...running into some heat issues...I replaced stock fans with different fans and I do not think they move enough air. I have two new jet engines on order to see if they can keep things cool.
  • Learned the hard way: first check the air flow direction ;-)
    The air must flow from the front to the back, and the lateral CPU fan must suck the air in.
ProSupport for Business
