Hermes_Muc
Jul 14, 2010Aspirant
Uncontrolled power-ups with RN Pro after Raidar Upg.
After upgrading my ReadyNAS Pro to RAIDiator 4.2.12, I now experience uncontrolled system starts. System now boots up uncontrolled at least three times a day when turned off. Of course, scheduler a...
stgadm
Aug 02, 2010Aspirant
ewok wrote: For those not using a schedule, are you powering off with the power button or through Frontview?
In my case, it doesn't seem to matter how the ReadyNAS is powered off (I tried both from FrontView and using the power button). I experience the random power up (sometimes a few minutes after the shutdown, sometimes a few hours later). It also doesn't matter whether the network cables are plugged in or not. So it's definitely not WOL that's causing this.
I started seeing there random power-ups after the upgrade to 4.2.11. Netgear support asked me to upgrade to 4.2.12 to see if that would fix the issue and it hasn't. I might try reverting back to 4.2.11 since some folks have had better luck with that version. (Netgear support has also suggested upgrading to 4.2.13beta ...)
I also have WOL and the schedule DISABLED.
Is the downgrade to 4.2.11 the best fix for this issue so far?
Thanks.
