Hermes_Muc
Jul 14, 2010Aspirant
Uncontrolled power-ups with RN Pro after Raidar Upg.
After upgrading my ReadyNAS Pro to RAIDiator 4.2.12, I now experience uncontrolled system starts. System now boots up uncontrolled at least three times a day when turned off. Of course, scheduler a...
ultrabike
Apr 20, 2011Aspirant
NOPE, Problem persists, EVEN after applying the latest FW RAIDator 4.2.16 + RAIDar 4.3.1...
My ReadyNAS Pro always turns off on time as programmed too, but RANDOMLY TURNS ON, some days it does, and some days it doesn't (so I have to go push the botton). This is a problem if I'm not in the premises and still want to use the scheduled power-on/off feature!
My ReadyNAS Pro is connected to a Trednet Green 8-port Gigabit Ethernet switch, not sure if this could be the problem (don't see how but who knows at this point!). Also I have a replacement unit, not sure if my replacement unit may be defective... NEVER HAD THIS PROBLEM WITH MY ORIGINAL PRO UNIT, or my ReadyNAS NV+ which I currently use to back up my PRO. My ReadyNAS NV+ ALWAYS turns off/on as programmed to and is hooked to the same ethernet switch my Pro is.
Last time I call support I was told that for some reason my ReadyNAS PRO time was off for some "strange" reason, so I changed the time servers it was looking at. When that failed I ran the timer internally, and still had problems. I then replaced the internal battery thinking it may have run out of juice, but that did not solve the problem either.The FW update seems to claim it solve some synch issues for the power saving options, but I still have a problem.
ANY SUGGESTIONS?
ANY SUGGESTIONS?
