Hermes_Muc
Jul 14, 2010Aspirant
Uncontrolled power-ups with RN Pro after Raidar Upg.
After upgrading my ReadyNAS Pro to RAIDiator 4.2.12, I now experience uncontrolled system starts. System now boots up uncontrolled at least three times a day when turned off. Of course, scheduler a...
BotanyBay
Sep 26, 2011Tutor
I just received an RMA unit for a different problem and the new unit has this issue. it always boots when power is first applied and if i turn it off with two presses of the blue button it comes back up in about 4 minutes.
I put in a single spare disk - updated the firmware to 4.2.17 which is what i was using before - powered down - installed 6 disks and it came right up. however unit will not stay powered off more than 5 min before reboot.
this is second rma
- original unit stuck not finding disks and saying readynas
- first rma temp 2 sensor went to 190F during weekly parity scrub of raid but normal otherwise probable thermal grease issue
- second rma arrived with 4.2.12 firmware (if memory serves) so flashed to 4.2.17 with spare disk but will not stay powered off
any suggestions? this is a pro business edition.
this is second rma
