Vyper007's avatar
Vyper007
UPS Shutdown Threshold ?
Hi I've got an APC 700KVA UPS attached to my Readynas Ultra 6+, theres an option to set what battery threshold the Readynas will shut down at in the event of a power cut, however what I cant find in the manual is what the "Auto" option does in that pull down menu. I get if I've got it set to 20% and the battery has 20% power left the Readynas will shut itself down, but when does it do it when Auto is set, does it just wait till the dying minute and shutdown at the last possible moment ?, the manual tells me nothing, does anyone here know ?
1 Reply
  • Auto uses whatever the UPS has set inside itself. You may be able to use PowerChute software on Windows to configure it. I believe the default is 60%.
ProSupport for Business
