xunforgivenx's avatar
xunforgivenx
USB Not attached but accessable i Explorer??
I cant do backups since USB is not attached under Volumes. It´s however fully accessable i Windows Explorer as USB_FLASH_3 :shock:
It´s located in the front
What am I doing wrong? Need to reset USB-port due to not safely removed or what has happend?
It used to work before I had to temporarily remove it
Readynas Duo, not latest firmware...
  • OOM-9's avatar
    OOM-9
    NETGEAR Expert
    Do you know which Duo hardware version you are running? What is the firmware version you have loaded on it?
    The Duo V1 and Duo V2 have different interfaces and it would be easier to assist with that information.
    You should have a USB option to unmount the drive.
  • OOM-9's avatar
    OOM-9
    NETGEAR Expert
    So you are not able to see the USB drive listed under the Volume/ USB Storage?
    (You should have an option to disconnect the usb drive in that section.)
    You mentioned that you had "temporarily removed it", did you plug it into a Windows machine?
    I have seen if you pulled the plug in some cases it will lock the drive on other systems. There is a flag that can be removed depending on what happened in the previous removing process.
  • Correct, its not listed under USB Volume but i can move and delete files from it in WinExpl
    I did not plug it in elseywhere, just had to move it fysically to get to some cables.
    I´m pretty sure I didnt make a safe removal via the powerbutton :(
  • Problem solved! :D
    Used the addon "Clean_USB_Storage" found on http://www.readynas.com/?page_id=617
    Followed instructions and the Duo found the drive directly
ProSupport for Business
