nsne
Dec 13, 2015Virtuoso
Volume: System volume root's usage is XX%.
Since adding new HDDs and resyncing, I've been getting the following error message:
Volume: System volume root's usage is XX%. This condition should not occur in normal conditions. Contact technical support.
It started at 81%, increased in 1% increments to 85%, and then fell to 84% — all over the course of about four days. The messages are appearing in the logs every ten minutes, and I'm getting alert e-mails with the same frequency.
I contacted tech support but there has been silence after creating the ticket. My 314 has just been sitting in diagnostic mode for the past 24+ hours with no word on whether or not they have identified the cause or a solution.
There are some other posts on this topic in the forums, but they seem related to specific apps (Logitech Media Server, Crashplan, btsync). Is there a "universal" way to go about identifying what might be eating up so much space in the 4GB rootfs partition? And what exactly constitutes the rootfs partition — everything but "data"?
I sent mdgm-ntgr a PM, too, but haven't heard anything.
- BrianL2NETGEAR Employee Retired
Hi nsne,
Could you provide us a copy of the device logs? Also PM me the case or ticket number you received from support.
Kind regards,
BrianL
NETGEAR Community Team- nsneVirtuoso
Just sent a PM to you. Eager to hear what the status is on the case and if any solutions are available.
- nsneVirtuoso
For the sake of posterity, the device logs. I wonder if the ten-minute intervals are exacerbating the problem?
Sun Dec 13 2015 14:23:22 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 14:13:21 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 14:03:18 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:53:17 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:43:15 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:33:13 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:23:10 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:13:08 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 13:03:07 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:53:05 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:43:03 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:33:01 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:23:59 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:13:56 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 12:03:53 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:53:51 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:43:49 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:33:47 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:23:45 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:13:42 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 11:03:40 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:53:38 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:43:36 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:33:34 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:23:32 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:16:25 System: Antivirus scanner definition file was updated to 201512130940. Sun Dec 13 2015 10:13:29 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 10:03:28 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:53:26 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:43:24 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:33:22 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:23:21 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:13:18 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 9:03:16 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:53:14 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:43:12 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:33:10 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:23:08 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:13:06 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 8:03:04 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 7:53:02 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. Sun Dec 13 2015 7:43:00 Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. RN314, OS 6.4.1, home network.
- mdgm-ntgrNETGEAR Employee Retired
About 1GB of the 4GB OS partition is being used by the LMS app alone.
# du -csh /var/lib/squeezeboxserver 691M /var/lib/squeezeboxserver 691M total # du -csh /usr/share/squeezeboxserver 307M /usr/share/squeezeboxserver 307M total
When apps store a lot of data on the OS partition that does contribute to getting error messages like this. There are a few other things as well that have contributed to the high root volume usage.The usage going up then down then back up again would relate to log truncation/pruning presumably.
Most things that are not stored on the data volume would be stored on the root volume.
- nsneVirtuoso
Any help here?
/dev/md0 is the OS partition. It is fuller than usual, but still appears to have quite a bit of space.
Maybe best to wait on support.
