Reply
Can we merge Netgear WAX610 Access Point and UniFi UAP-AC-Pro
ebenus_it
Follower
Hello everyone,
I want to know if is it possible to merge all my execting access points in one SSID (Netgear WAX610 5No's & UniFi UAP-AC-Pro 8No's)
if possible please let me know how we can do it.
Thanks,
Message 1 of 5
Re: Can we merge Netgear WAX610 Access Point and UniFi UAP-AC-Pro
What are these? Google isn't much help.
You can give WiFi sources whatever SSID and password you like, whether they will play nicely together is another matter.
If you want to flood the place with a seamless SSID that WiFi clients can move between without interruption as they move from source to sources, you need Mesh WiFi technology. As yet different brands of WiFi source don't work together in a Mesh network.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your question.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 5
zombiecatchers
It is not possible to physically merge two different access points from different manufacturers like the Netgear WAX610 and UniFi UAP-AC-Pro. While both devices are designed to perform the same function, they have different hardware and software specifications, and they use different management systems.
However, it is possible to integrate the two access points into a single network. To do this, you will need to configure both devices with the same network settings, such as SSID, security settings, and IP address range. This will allow users to seamlessly move between the two access points without any interruption in their network connection.
You can also configure one access point as the primary router and the other as a wireless repeater or bridge. This will help to extend the range of your wireless network, allowing you to cover a larger area. However, keep in mind that the performance of the wireless network may be affected by the distance and interference between the two access points.
Message 3 of 5
zombiecatchers
Yes, it is possible to merge all your existing access points into one SSID to create a seamless wireless network.
Here are the general steps to follow:
  1. Log in to the configuration interface of each of your access points using a web browser.
  2. Navigate to the wireless network settings or WLAN settings section.
  3. Look for the option to configure the SSID and set it to the same name on all access points.
  4. Ensure that the zombie catchers mod apk encryption type and passphrase, are identical on all access po
  5. Save the settings on each access point and reboot them if necessary.
It is also recommended to adjust the power levels and channel settings on each access point to minimize chatsonic interference and optimize coverage.
Note that while this setup can simplify network management and improve roaming, it may not be suitable for all environments and may require additional configuration and tuning.
Message 4 of 5
Anakjoi
@ebenus_it wrote:
Hello everyone,
Thanks,
Yes its possible, If you want the exact solution please let me know, I am available 24 by 7 to assist you.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3143 views
  • 0 kudos
  • 4 in conversation
Announcements
