Reply
Compatible PoE Wireless Access Points for WAX202 acting as router
pedroespo
Follower
My current setup is a WAX202 (WAX202-100NAS) AP set up as a router. The other half side of my house has weak signal, I would like to purchase an access point that is strictly PoE so I can do a network drop on the other side of my house to this AP, this drop will not have access to a DC power outlet and must be strictly PoE for this AP. What products are compatible and you guys would recommend so I can do this? Thank you for all the assistance, I have been looking around and unable to find products anyone recommends.
Essentials WiFi 6 (WAX202)
Message 1 of 6
Accepted Solutions
nmhTester
NETGEAR Expert
Re: Compatible PoE Wireless Access Points for WAX202 acting as router
WAX214v2, WAX218, WAX220 all will be good match for WAX202 acting a router.
Message 3 of 6
All Replies
ErwinL
NETGEAR Moderator
Hello pedroespo,
And welcome to the NETGEAR Community! 🙂
Do you plan to set bridging where you will set the POE access point to get wifi signal from WAX202 and then have wired connections of devices to the access point on the other end?
Have a lovely day,
Logan
Netgear Team
Message 2 of 6
nmhTester
NETGEAR Expert
Message 3 of 6
schumaku
Guru
Glad to read from you here @nmhTester !
Does this new WAX214v2 support - different from the current WAX214 and WAX218 releases - a bigger selection of 80 MHz channels? With the limited 5 GHz channel availability, deploying the models suggested (either multiple, or along other AP and routers) is very difficult due to obvious interferences called - lack of options to have dedicated 5 GHz coverage on air.
Needless to repeat it again: The current limited selection of VT80 channels (read: just one set!) is not acceptable - no alternate channels, no DFS, ...
TIA
-Kurt
Message 4 of 6
vikumar
Tutor
Hi @pedroespo
Please find the WAX220 features, it may help in finding correct AP for your setup.
WAX220 FEATURES:
  • Wi-Fi 6 (802.11ax) capable
  • Dual band: 2x2 2.4 GHz radio, 3x3 5GHz radio
  • Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4GHz band and 3600 Mbps on 5GHz bands
  • Supports till 160MHz channel width.
  • PoE+(802.3at) powered
  • 2.5Gbps Ethernet Link
  • Support MU-MIMO function on both 2.4GHz and 5GHz radio.
  • 128 concurrent client connections (64 clients per radio)
  • 4 SSID support
  • WPA3 authentication support
Thanks,
Basavaraj
Message 5 of 6
schumaku
Guru
To compare with the existing router, here the WAX214 v2.
WAX214 v2 Features
  • Dual band: 2x2 2.4 GHz radio, 2x2 5GHz radio
  • Supports IEEE802.11ax/ac/a/b/g/n wireless standards with up to 574 Mbps data rate on 2.4 GHz band and 1200 Mbps on 5 GHz bands
  • Supports a channel width of up 80 MHz on the 5 GHz band.
  • PoE+ (802.3at) powered
  • 1 Gbps Ethernet Link
  • Supports MU-MIMO on both the 2.4 GHz radio and 5 GHz radio.
  • 4 SSIDs supported
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2699 views
  • 2 kudos
  • 5 in conversation
Announcements
