Cartier
Jul 26, 2024Apprentice
Guest network
Hello everyone, I ask for help if it is possible to create a guest network with this access point, via NETGEAR Insight???
Thanks for the help.
Access Point WiFi 6 AX1800 WAX610
Yes, this makes about sense.
Don't be confused that all Insight managed AP are - for this giest network - local, private RFC1918 IP addresses, and the SSOD won't allow seamless roaming.
What expectations, and more what environment (like a multi-VLAN and IP-subnet capable router) you have in place?
The minimum implementation .- in absence of a VLAN-capable router - would be to define a new SSID and security for guest Internet access plus NAT mode where each WX6xx or WBE7xx will do a many2one NAT to the AP LAN interface. This means the guests won't be able to communicate on the local LAN and subnet..
