- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Pro Safe Wireless Access Point WN370
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have purchased four of these Wireless Access Points without realising that I require to purchase a controller to manage these thinking they were stand alone devices. What is the most inexpensive controller I require to purchase to make these things work. The WC7600 is far to powerfull for what I require. What are my options please.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Just for the clarify the WN370 can be managed by WC7600, WC9500, WC7600v2, WC7500 controllers.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Pro Safe Wireless Access Point WN370
Hi Murrayfield,
Welcome to the community! 🙂
I'm afraid to inform you that the WN730 can only be managed by the WC7600 wireless controller. Since you need a standalone access point, I suggest the WAC510 access point. Kindly check its specification and comparison with other NETGEAR access points on the data sheet here.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DaneA
Thanks for the info. I did a bit more research in between posting the question and receiving your reply and I have a query. One of the documents I searched on came up with the following (page 2) https://www.netgear.com/images/pdf/WC7500_DS_30Mar16.pdf which seems to show support for the WN370 by the WC7500. Well I hope so 'cos I have bought one 😉
Cheers
Ian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the WC7500 also supports the WN370. From my previous response to you, I have based my answer on page 1 of the WN370 installation guide here where it says "The WN370 access point can only be deployed in a network managed by a ProSAFE WC7600 wireless controller" under the section of 'Set Up the Access Point.'
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Guys thanks for the update and clarification
Cheers
Ian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
i have too one WN370
and this one is not recognized by my WC7500
Does really the WC7500 is compatible with WN370 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can categorically say that the wc7500 will manage the wn370 I managed to get four working today. The first two were easy but the second two were a problem. In the end I rebooted the wc7500 then plugged in each AP individually factory reset the AP found it on the controller then edited the AP and the WC to fit into my network op address scheme. Worked a treat
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks MurrayField I try that
which firmwares do you have ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
WC7500. 6.0.1.0
WN370. 6.0.1.0_3875
Regards
Ian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just have bought THREE wn370 to realize that I need to buy also a @#!? additional "machine" to have them configured. Is there any other mean to configure them? telnet? https? ftp?. When they first are powered I presume they send a DHCP discover and "WireSharking" the communications (yes, I have a primitive HUB not SWITCH that can propagate packets) so I could know their IPs. No chance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
WN370 can only be managed and configured by the following WLAN controllers.
WC7500, WC7600, WC7600v2, WC9500. You have to buy one of these controllers to make WN370 work, and there is no other option to configure it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So no chance with the "http://192.168.0.160" that is used to obtain the logs when a WC cannot discover the unit? :
