Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Setting min. client RSSI for WAC510 AP
dbrewe
I have a couple WAC510 APs and I would like to configure load balancing, specifically the minimum client RSSI parameter. I think I understand the basic concept, namely that if a client RSSI falls below a specified threshold, the AP will disconnect that client, or refuse to connect a new client. However, as far as I know, the RSSI is a signal level, e.g. -50dBm. However, the management interface for the WAC510 shows values between 1 and 50 (w/ no units). Can anyone tell me how the values 1 to 50 translate to signal levels?
thanks
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: Setting min. client RSSI for WAC510 AP
Hi dbrewe,
Welcome to our community! 🙂
As per our engineering team, The client RSSI mentioned in the load balancing is a positive scale value. It is calculated using the following formula:
Positive Scale Value = 95 + (Wireless client RSSI in negative value)
example:
If a client RSSI -45, then the positive scale value is 50.
John
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1831 views
  • 0 kudos
  • 2 in conversation
Announcements
