richford's avatar
May 03, 2022
WAX214 wifi second unit without ethernet
I want to connect two WAX214's to get full coverage aroundthe house.
One of them I can connect via ethernet to the router - which is a BT Smarthub 2.
But the second one will be in an area of the house that does not have any CAT 6 cabling.
Can this be done with the WAX214?
(It sounds like a simple question but I've searched high and low and cannot find the definitive answer.)
  • plemans's avatar
    No.
    the WAX214 doesn't have wifi repeating.
    Its needs to be hardwired in.
    • richford's avatar
      richford
      Tutor
      Thanks for the swift reply!! That takes care of that then.
      Will the WAX610 do this then (or rather a pair of them)?
      • plemans's avatar
        If you're wanting a mix of wired and wireless access points, I'd be looking at the orbi line. There's always the pro line if you're wanting a business setup.
ProSupport for Business
