Reply
WAX625 frequent freeze
zekou
Tutor
Hi,
I could not find/select WAX625 from the dropdown in the "Associated Products" field, so this is actually a thread for NETGEAR Cloud Managed Wireless Access Point (WAX625) - WiFi 6 Dual-Band AX5400 Speed.
I have been running WAX625 behind main router/firewall operated on OPNSense. This device is replacement I have been issued through RMA process as a replacement for WAX220 which was having connection drop issues (described in this thread), before it was addressed earlier this year.
From time to time (sometimes few times a week, sometimes every two weeks) this device will completely freeze and all my connections will drop. It becomes useless at that point and never self-recovers. When I check the device visually, the most left LED is always turned orange. At the same time (when this failure occurs), I am not experiencing any connectivity issues with my main Mac computer which is connected directly using CAT6a cable to the router (bypassing Netgear WAX625 AP). So I am eliminating possibility that there are router/OPNSense issues here, as I wasn't experiencing this with my other (temp) LinkSys AP with same configuration.
I am running the latest firmware 10.8.8.7 on this WAX625 AP. By the way the device is connected via PoE+ cable to main router, not using AC adapter.
Could someone please advise? I am open to share detailed logs from the device in DM if anyone is willing to look into this.
#WAX625 #Freezing
Message 1 of 3
Pramendra
NETGEAR Expert
Re: WAX625 frequent freeze
Hi @zekou
Please share the device logs to my business email id. I am sending my email through a DM.
Thanks!
NETGEAR NFB Wireless.
Message 2 of 3
zekou
Tutor
Hi @Pramendra ,
Thank you for the follow up. I have just sent logs to your business e-mail as indicated in your DM.
Thank you for looking into this!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 489 views
  • 0 kudos
  • 2 in conversation
Announcements
