Reply
WNAP320 upgrade sequence
JanHruska
Tutor
I would like to upgrade a standalone WNAP320 2.1.1 to the current firmware. The upgrade sequence described in http://kb.netgear.com/31401/WNAP320-Firmware-Version-3-5-20-0?cid=wmt_netgear_organic is contradictory, gives two examples:
1. AP running 2.x, first upgrade to 2.1.6. Then upgrade to 3.5.20.0
2, Example firmware upgrade sequence for WNAP320 from 2.x:
V2.1.11 -> V2.1.12 -> V3.5.20.0 - Correct sequence
It also implies that 2,1,5 is the earliest version that can be upgraded for WNAP320 ("Upgrade initiated from other 2.x firmware version is not supported.").
What is the correct sequence?
Message 1 of 3
Accepted Solutions
RaghuHR
NETGEAR Expert
Re: WNAP320 upgrade sequence
Hi JanHruska,
For your WNAP320 which is having the firmware version 2.1.1 please find the below correct squence.
2.1.1 -> V2.1.6 -> V3.5.20.0
Thanks
Raghu
Message 2 of 3
All Replies
RaghuHR
NETGEAR Expert
Hi JanHruska,
Thanks
Raghu
Message 2 of 3
JanHruska
Tutor
Raghu,
It worked. Thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3246 views
  • 1 kudo
  • 2 in conversation
Announcements
