Reply
WNDAP360
chrisbf1
WNDAP360
I have a wndap360 that I have taken off site, it was preconfigured to work with a controller. i want to re utilise it. I turned it on, and all i get is the the amber flashing power light. i have found out its DHCP address and can logon it. This does not give me any config option, Help!!! i dont really want to take it back to site to plug back in to the controller
Model: WNDAP330|PROSAFE 802.11N DUAL BAND WIRELESS ACCESS POINT|EOL
Message 1 of 4
Accepted Solutions
chrisbf1
Re: WNDAP360
so all sorted now
what I did was downgraded the firmware as it was on 2.3...... , i took it back to 2.1 ..... and I can now manage it as i want to
thank you for your help
Chris
Message 3 of 4
All Replies
JohnRo
NETGEAR Employee Retired
Re: WNDAP360
Hello chrisbf1,
Welcome to the community!
The best way is still to push a standalone firmware to the AP. Eve if it has been reset to default I don't think it will go back to standalone mode. When an AP is connected to a controller, it is using a "thin firmware" pushed by the controller. To get it back to a basic AP, you'll need to have a standalone AP downloaded to it. Do you happen to know the IP of the AP?
Thanks,
Message 2 of 4
chrisbf1
Re: WNDAP360
so all sorted now
Chris
Message 3 of 4
JohnRo
Re: WNDAP360
Hi chrisbf1,
Good know. Can I please request for you to mark your reply as "Accept as Solution". This should help other community members if they run into the same scenario.
Have a great day!
Thanks,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3907 views
  • 0 kudos
  • 2 in conversation
Announcements
