- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
CAX80 Multi-gig ethernet port dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 Multi-gig ethernet port dropping
spent a year with tech support to no avail.
i only use it as a cable modem, no routing or wifi.
i still drops the 2.5g port to 1gig on occasion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yikes! I guess I should return to Amazon while I still can. No other products like it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
updating to the new firmware from march 22' fixed the issue for me. It was/is definitely a firmware issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is this however not sure if it will fix:
This fixed it for me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
I had upgraded to that firmware and it got really bad. So, the Netgear tech support told me to downgrade to the prior firmware. Just not sure if they really know what is going on.
So, you are sure the problem with the 2.5 port is now fixed for you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No issues since upgrading to the V2.1.3.7 firmware (was V2.1.3.5 before)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. How long have you been on the new firmware without the issue? A few days or weeks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A few days so far, but the issue was VERY noticeable and instant before. I would notice the D/Cs instantly with the prior firmware version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Is the device you have connected to the multi-gig port one that can handle more than 1 Gbps?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's July 2022 mine is doing the same thing random disconnects, and when in a game that 15 drop is terrible. Very disappointed in this modem. Paying for 1200 and only can use 947.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you have connected to the multi-gig port?
What CAT# lan cable are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine does the same thing
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With my switch to AT&T Fiber only 2 months after having bought this defective modem, I am at least thankful of not having to worry about the connection. The AT&T gateway actually connects at 5 Gig, so even higher than the Netgear port at 2.5 Gig.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup same problem here on my modem. I am back to using the one gig ports. Not happy either this modem has been out long enough for this problem to be solved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wanna try a CAT6A STP cable from this port to the PC?
I'm currently using a CAT6A STP cable from this port on mine to a NG XS505M multi gig switch. Been working for weeks here.
@wtpeters wrote:
Cat 6, one computer, extensive troubleshooting with cable company. Report was the modem. That is my conclusion. This modem has not worked properly on the 2.5 gig port since I've owned it. Latest firmware update went back to 2.1.3.5. The problem persists. On the one gig ports it is flawless. I have turned off the radios on both wiifi. The problem lies in the modem.
- « Previous
- 1
- 2
- Next »
