- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000v2 Will not boot
- Mark as New
- Bookmark
- Subscribe
- Permalink
We had this exact same thing happen. Xfinity had a multi-day outage, and part way through we discovered that our modem had the all-lights-blink problem.
We called Netgear support and they told us to pound sand because the unit was 13 months old and the warranty was 12 months.
I am 99.999% sure that the problem is that the firmware is corrupt and simply reflashing it would bring it back, but Netgear seems to be unwilling to actually do this, preferring instead to just generate more eWaste. What a shame.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000v2 Will not boot
@nsayer wrote:We had this exact same thing happen. Xfinity had a multi-day outage, and part way through we discovered that our modem had the all-lights-blink problem.
If you actually have the CM1000v2 like the title says, it is a cable modem. Refreshing the firmware is at the sole discretion of the ISP, not the cable modem manufacturer.
If you ask technical support at Xfinity, they should refresh your firmware for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR could reflash this unit with the original factory firmware. It’s foolish to suggest that they couldn’t do so if I mailed it back to them. But they simply won’t, preferring that I throw an otherwise perfectly useful cable modem into the trash because it missed the warranty window by 20 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the ISP cable coax line disconnected, have you tried a 30-30-30 reset on the modem with nothing connected to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
K welp, sorry can't help beyond this. Warranty is warranty. You'll need to find another modem and move on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya I wish mfrs had more repair options. Seems like router and modem Mfrs don't and rather toss it and go get another. Consumerism at it's finest. 🙄
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you will potentially run into this problem again. Home users can't "flash" modems. If they could, it'd allow them to modify the provisioning file that sets speeds/service parameters and would open them up for hacking. That's why its locked down. it's not specific to netgear. Its all modem manufacturers. So while I would still recommend other modems, I'd probably only go the CODA56 and not the S33. Reason not the s33, its very unsure if it'll get approved for xfinity's "next gen" speeds. There's a S34 on their site (unreleased) that says it has high split speeds, so I'd imagine that'll be on there at some point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@nsayer wrote:
Xfinity can’t reflash the firmware because the firmware corruption prevents booting at all.
You do not know for certain what has failed. Are you willing to risk the cost for shipping, labor, and etc. to find out the problem is something besides firmware corruption?
Have you tried a different power adapter in case that is the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I tried a different power supply. I’m not that stupid.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
