Orbi WiFi 7 RBE973
Reply
CM1100 has speed lower than my internet provider confirmed
locnt
(Firmware Version
V2.01.02)
Hello,
I just bought the modem. The internet went smoothly; however, the speed is much slower than expected.
My Xfinity provider confirmed with me that my download speed is 60 Mbps from their end. However, no matter how I tested (on both speedtest.com and http://speedtest.xfinity.com/), my speed is only about 18 Mbps.
Before renting their own modem to see if I have a better result, I still want to try if there is a way to fix it myself.
Thanks,
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 5
Guru
Re: CM1100 has speed lower than my internet provider confirmed
Try a different test PC. If the ISP confirms speeds are good up to the modem then check your PC and or connected external router if you have one connected. Directly connect a wired PC to the modem with out the router and speed test there. Ensure LAN cabling is of good working quality. CAT6 is recommended.
Message 2 of 5
locnt
I tried with 2 different laptops, both wired and wireless. No different results.
Should I try changing any settings?
Message 3 of 5
Guru
Nothing in the CM to set. LAG should be disabled is all. If you tested different PCs and such. I would presume the modem needs to be RMAd.
@vkdelta
Message 4 of 5
vkdelta
NETGEAR Expert
you dont need LAG for 60 Mbps.. LAG is for >1Gbps service.
Have you tried testing DIRECTLY to the modem?
What ethernet adapter do you use?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2257 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
