Orbi WiFi 7 RBE973
Reply
CM1100 need to reset modem constantly with COX
Larry2024
Guide
Hi all, used to be every few days but now I am having to reset the modem multiple times a day and it is driving me nuts.  Here is the connection after a factory reset.  Many thanks!
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel855000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
Downstream Bonded Channels (Partial Service)
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25621855000000 Hz-14.8 dBmV32.5 dB23050907825405
2Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
3LockedQAM2567771000000 Hz-11.0 dBmV37.2 dB21980037316125
4LockedQAM2568777000000 Hz-12.0 dBmV38.4 dB1984183618264438
5LockedQAM2569783000000 Hz-11.5 dBmV35.6 dB1958429912371601
6LockedQAM25610789000000 Hz-12.0 dBmV38.4 dB2198994714091794
7LockedQAM25611795000000 Hz-12.8 dBmV37.8 dB21995225324117
8LockedQAM25612801000000 Hz-12.0 dBmV38.4 dB21999242356145
9LockedQAM25613807000000 Hz-13.0 dBmV37.7 dB22003836351172
10LockedQAM25614813000000 Hz-13.0 dBmV37.6 dB22006003416196
11LockedQAM25615819000000 Hz-12.9 dBmV37.7 dB22012145333179
12LockedQAM25616825000000 Hz-14.3 dBmV36.6 dB22015422358138
13LockedQAM25625117000000 Hz-1.1 dBmV44.1 dB1908978061706918
14LockedQAM25626123000000 Hz-1.7 dBmV36.4 dB1951574474579133
15LockedQAM25627129000000 Hz-1.8 dBmV43.6 dB1821464661168634
16LockedQAM25628135000000 Hz-2.5 dBmV43.2 dB18215535989712248
17LockedQAM25629141000000 Hz-3.2 dBmV43.7 dB614580849138362
18LockedQAM25630147000000 Hz-3.1 dBmV43.8 dB95823641278022982
19LockedQAM25631153000000 Hz-3.4 dBmV43.7 dB486935129565084
20LockedQAM25632159000000 Hz-2.7 dBmV44.3 dB7653978804914270
21LockedQAM25633165000000 Hz-2.9 dBmV39.8 dB8669753663312321
22LockedQAM25634171000000 Hz-2.9 dBmV44.3 dB9507847661512718
23LockedQAM25635177000000 Hz-2.8 dBmV44.2 dB220364611104322196
24LockedQAM25636183000000 Hz-3.2 dBmV33.9 dB18262007624111163
25LockedQAM25637189000000 Hz-3.1 dBmV44.0 dB522226920282576
26LockedQAM25638195000000 Hz-3.3 dBmV27.4 dB253162228123198
27LockedQAM25639201000000 Hz-3.3 dBmV44.4 dB877582144617863
28LockedQAM25640207000000 Hz-3.4 dBmV41.1 dB22072957776915987
29LockedQAM25641213000000 Hz-3.1 dBmV36.5 dB88344142204313062
30LockedQAM25642219000000 Hz-3.3 dBmV44.8 dB19541181642111580
31LockedQAM25643225000000 Hz-3.3 dBmV44.7 dB1065592357119550
32LockedQAM25645237000000 Hz-3.6 dBmV44.6 dB880059832505339
Upstream Bonded Channels
1LockedATDMA116900000 Hz43.5 dBmV
2LockedATDMA223500000 Hz44.8 dBmV
3LockedATDMA329900000 Hz44.3 dBmV
4LockedATDMA436300000 Hz44.3 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2, 3159300000000 Hz-6.8 dBmV40.8 dB296 ~ 7895870176311492122429355
2Locked0, 1, 2, 3160918000000 Hz-16.2 dBmV27.8 dB1108 ~ 2987620283241160781531209
Upstream OFDMA Channels
1Locked3, 4, 9, 10, 11, 12, 13636800000 Hz40.0 dBmV
2Not Locked3, 4, 9, 10, 11, 12, 1300 Hz0.0 dBmV
Message 1 of 29
Accepted Solutions
Guru
Re: CM1100 need to reset modem constantly with COX
Looks good. Some channels are a bit far in power between the channels however if it's working. Let it run.
Message 25 of 29
All Replies
Kitsap
Master
Your power levels are way low and you have a large number of correctable/uncorrectable code words.
The power levels should be between +7 dBmV and -7 dBmV.  For reference, see the top two sentences on this support document.  https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
The next time you copy the connection status page, include the system up time.  The correctable/uncorrectable counts reset to zero when you boot the modem.  Not knowing how long it took your modem to reach the values indicated is a problem.
You have some serious line issues that need to be resolved by your ISP.  You can check your coax cable for damage, corroded or loose connections, old splitters, amplifiers, etc. that can negatively impact your signal.  Keep in mind, some of your issues could be house wiring your ISP would charge you to correct.
Message 2 of 29
Larry2024
Guide
Thank you Kitsap,
I do have a Cox tech coming out tomorrow, but I'd like to understand the issue a little bit so thank you very much for taking the time to review this issue.
I don't know if there is a splitter in the box outside or not but there is only a F81 connector connecting the cables from the box and where the modem is located.  The wiring is original so 24 years old.
The connection up time when I posted was no more than 10 mins.
Here is the update connection status with system up time.  Way more correctable and uncorrectable codewords now.
Startup Procedure
SecurityEnableBPI+
1LockedQAM25621855000000 Hz-14.3 dBmV35.5 dB3286931782063622661
2LockedQAM2565759000000 Hz-10.9 dBmV27.4 dB57742411653636655567144
3LockedQAM2567771000000 Hz-10.5 dBmV39.0 dB3276389391527315660
4LockedQAM2568777000000 Hz-11.4 dBmV38.9 dB176077955284318574636
5LockedQAM2569783000000 Hz-11.0 dBmV39.2 dB1361054815432751456156
6LockedQAM25610789000000 Hz-11.5 dBmV38.8 dB3276416742308621979
7LockedQAM25611795000000 Hz-12.2 dBmV38.2 dB3276563671607616748
8LockedQAM25612801000000 Hz-11.5 dBmV38.7 dB3276602631576516277
9LockedQAM25613807000000 Hz-12.4 dBmV38.0 dB3276673491558516455
10LockedQAM25614813000000 Hz-12.5 dBmV37.9 dB3276670451589216786
11LockedQAM25615819000000 Hz-12.4 dBmV38.1 dB3276724001654116954
12LockedQAM25616825000000 Hz-13.7 dBmV37.1 dB3276732141745318275
13LockedQAM25625117000000 Hz-1.0 dBmV44.5 dB562190016348572081
14LockedQAM25626123000000 Hz-1.5 dBmV44.1 dB174068536155663218077
15LockedQAM25627129000000 Hz-1.7 dBmV44.3 dB416222144250459304
16LockedQAM25628135000000 Hz-2.5 dBmV44.2 dB67786450143318211413
17LockedQAM25629141000000 Hz-3.2 dBmV44.3 dB82571893184982300014
18LockedQAM25630147000000 Hz-3.1 dBmV44.3 dB98404555197061333097
19LockedQAM25631153000000 Hz-3.4 dBmV44.3 dB118219532257729446135
20LockedQAM25632159000000 Hz-2.7 dBmV44.7 dB127242183242042431759
21LockedQAM25633165000000 Hz-3.0 dBmV42.4 dB71911075189290368675
22LockedQAM25634171000000 Hz-2.9 dBmV44.6 dB57851126116772198712
23LockedQAM25635177000000 Hz-2.8 dBmV44.7 dB69636261104833226957
24LockedQAM25636183000000 Hz-3.1 dBmV37.0 dB79070806115492291264
25LockedQAM25637189000000 Hz-2.9 dBmV44.5 dB3229894099232262118
26LockedQAM25638195000000 Hz-3.2 dBmV32.8 dB4866532014813711356191
27LockedQAM25639201000000 Hz-3.1 dBmV44.7 dB64652606121776275945
28LockedQAM25640207000000 Hz-3.2 dBmV43.3 dB79938129178392504176
29LockedQAM25641213000000 Hz-2.9 dBmV40.0 dB74499092135016319912
30LockedQAM25642219000000 Hz-3.1 dBmV45.0 dB141626626126901333968
31LockedQAM25643225000000 Hz-3.2 dBmV44.9 dB147492153138828316362
32LockedQAM25645237000000 Hz-3.4 dBmV44.8 dB11205103392936155391
2LockedATDMA223500000 Hz44.3 dBmV
4LockedATDMA436300000 Hz44.8 dBmV
1Locked0, 1, 2, 3159300000000 Hz-6.6 dBmV40.8 dB296 ~ 78951043281678213193654318797
2Locked0, 1, 2, 3160918000000 Hz-15.7 dBmV31.3 dB1108 ~ 298725611780137348268122335
1Locked3, 4, 9, 10, 11, 12, 13636800000 Hz40.3 dBmV
Current System Time: Tue May 07 19:17:47 2024
System Up Time: 2:03:09
Message 3 of 29
Guru
The levels are also all over the place. They should be within 3.5dbmv of each other.
Something is squirrelly with the line.
Message 4 of 29
Larry2024
Guide
Thank you all for the reply.  Cox tech came out this morning, he said the cable from the outside to the house needs to be replaced (he measured and said there is a 90% power drop).
He said to take care of this first and if issue still occur afterward than he can add a new cable from my house to where the modem is located.
Will report back and share the new connection status once the cable is replaced.
Message 5 of 29
Guru
That should help as well the the correctables and un-correctables as those should be zeros across the board.
Also have the tech check the modems events logs. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Message 6 of 29
Kitsap
Master
Sounds like a worthwhile tech visit.  If your internal wiring, splitters, and etc. are more than a half dozen years old, it would be worthwhile to push to have that also replaced.
Message 7 of 29
Larry2024
Guide
Cox said it will take up to 12 weeks to replace the outside line (need city permit) but funny thing happened yesterday, ATT Fiber crew outside digging holes to install fiber cables and they severed my Cox line.  Spent a few hours tried to reconnect the cables but the hack job failed so today they replaced the outside line.  Here is the new connection status:
Startup Procedure
Acquire Downstream Channel237000000 HzLocked
SecurityEnableBPI+
1LockedQAM25645237000000 Hz7.9 dBmV45.5 dB40714716800
2LockedQAM2561735000000 Hz5.8 dBmV43.0 dB40595545500
3LockedQAM2562741000000 Hz6.2 dBmV43.1 dB40595790900
4LockedQAM2563747000000 Hz5.5 dBmV43.2 dB40596226900
5LockedQAM2564753000000 Hz5.9 dBmV43.4 dB40596752200
6LockedQAM2565759000000 Hz6.1 dBmV42.6 dB40597069700
7LockedQAM2566765000000 Hz5.5 dBmV42.8 dB40597456800
8LockedQAM2567771000000 Hz6.1 dBmV43.5 dB40597849400
9LockedQAM2568777000000 Hz5.6 dBmV43.1 dB40598201600
10LockedQAM2569783000000 Hz5.3 dBmV43.1 dB40598576300
11LockedQAM25610789000000 Hz5.8 dBmV43.4 dB40598938300
12LockedQAM25611795000000 Hz5.0 dBmV43.0 dB40599344400
13LockedQAM25612801000000 Hz5.2 dBmV43.1 dB40599712100
14LockedQAM25613807000000 Hz5.4 dBmV43.4 dB40600051500
15LockedQAM25614813000000 Hz4.6 dBmV42.9 dB40600399200
16LockedQAM25615819000000 Hz5.0 dBmV43.1 dB40600909000
17LockedQAM25616825000000 Hz4.4 dBmV42.8 dB40601223800
18LockedQAM25617831000000 Hz3.8 dBmV42.3 dB40601586100
19LockedQAM25618837000000 Hz4.5 dBmV42.8 dB40601931400
20LockedQAM25619843000000 Hz3.8 dBmV42.4 dB40602375500
21LockedQAM25620849000000 Hz3.6 dBmV42.2 dB40602681600
22LockedQAM25621855000000 Hz4.2 dBmV42.6 dB40603084300
23LockedQAM25622861000000 Hz3.5 dBmV42.2 dB40603418400
24LockedQAM25623867000000 Hz3.6 dBmV42.3 dB40603845000
25LockedQAM25624873000000 Hz3.6 dBmV42.1 dB40604158000
26LockedQAM25625117000000 Hz7.8 dBmV44.5 dB40604593300
27LockedQAM25626123000000 Hz7.9 dBmV44.6 dB40604978500
28LockedQAM25627129000000 Hz8.1 dBmV44.9 dB406053601250
29LockedQAM25628135000000 Hz7.9 dBmV45.0 dB40605729210
30LockedQAM25629141000000 Hz7.8 dBmV45.3 dB40606070700
31LockedQAM25637189000000 Hz7.9 dBmV45.4 dB40605871900
32LockedQAM25640207000000 Hz8.0 dBmV45.5 dB40605974100
1LockedATDMA116900000 Hz37.3 dBmV
2LockedATDMA223500000 Hz37.8 dBmV
3LockedATDMA329900000 Hz37.5 dBmV
4LockedATDMA436300000 Hz38.0 dBmV
1Locked0, 1, 2, 3159300000000 Hz7.3 dBmV43.3 dB296 ~ 78951623753096329535070
2Locked0, 1, 2, 3160918000000 Hz3.4 dBmV40.0 dB1108 ~ 2987186671750577231140
1Locked3, 4, 9, 10, 11, 12, 13636800000 Hz32.3 dBmV
Current System Time: Thu May 23 13:41:58 2024
System Up Time: 2:29:43
Message 8 of 29
Guru
Seems still a bit all over the place in power levels. Some channels are a bit too high. Something you can try get a -6Dbm coax line attenuator in put behind the modem and see if this gets the power down for those channes.
Correctables and Un-currectables are way better though.
Message 9 of 29
Larry2024
Guide
Thank you FURRYe38, just ordered one from Amazon, will report back when in a couple of days.
I really appreciate everyone's help!
Message 10 of 29
Guru
Message 11 of 29
Guru
Probably don't have the attenuator yet but seems better if a bit all over.
Is it any more stable? If its stable, I'd leave it without the attenuator.
Is this directly connected to the modem? meaning the outside line comes into the house and goes directly to the modem?
Message 12 of 29
Larry2024
Guide
I see the correctable and uncorrectable codewords for the 8 channels that are above
7 dBmV starting to build up (not a lot, fewer than one hundred) while all other channels are at 0 after 20 hours up time.  Connection seems stable and there are no warning or critical events logged.
Yes, it is a direct connection from the outside to the modem.  The cable inside is 24 yrs old and there is one female to female connector to replace a splitter that is no longer needed.
Message 13 of 29
Guru
A few errors aren't a big deal but if its building to fast, its indicative of something needing replacing.
Any chance you can put the modem right where that female-female connection is? Every connection adds a point of failure/errors. If that clears things up, it could be a bad connector or even ends on the cable.
Message 14 of 29
Larry2024
Guide
Unfortunately the female to female connection is up in the attic, there is no outlet and gets very hot up there (Phoenix, AZ).
Message 15 of 29
Guru
Thats does make it a bit more challenging 🙂
If its more stable and not having any drops, I'd just sit on it. You can run higher power levels but they can have instabilities if its to high. If its working follow the old golden principle of "don't fix what isn't broken".
Message 16 of 29
Larry2024
Guide
Thanks plemans!  I will run the current setup until the 6db attenuator gets here tomorrow.  Take a snapshot of the connection status.  Put the attenuator in and let it runs the same duration, take another snapshot and post results here for all the experts to review.
Message 17 of 29
Kitsap
Master
It is good practice to reboot the modem after you install the attenuator.
Message 18 of 29
Larry2024
Guide
Yes, I will do that, thanks for the suggestion.
Message 19 of 29
Larry2024
Guide
Hi all, I am back with another set of connection status.  This is from yet another new outside line, put in by Cox today (first time, AT&T cut my line while putting down fiber cable on 5/23).  This is without any attenuator (I do have a 6db and a 3db).  Should I give the 6db attenuator a try to bring down the power level?  Thanks...NewLine1.pngNewLine2.png
Message 20 of 29
Guru
Yes.
Good on the correctables and un-correctables.
Hows the event log look?
Message 21 of 29
Larry2024
Guide
Message 22 of 29
Guru
Message 23 of 29
Larry2024
Guide
Up for 19 hours and all the channels with above 7 dBmv started to accumulate correctables and un-correctables, with notice events only.  I just added the 3db attenuator and will let it run for a day to see if it is any better.  If not I will put the 6db on.  This is the connection status with the 3db.  Thanks!3db1.png3db2.png
Message 24 of 29
Guru
Message 25 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 6044 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
