Chazz's avatar
Chazz
Tutor
Oct 08, 2015
CM500 status log for high db power on upstream
1LockedATDMA535120 Ksym/sec34800000 Hz54 dBmV
2LockedATDMA545120 Ksym/sec27900000 Hz54 dBmV
3LockedATDMA555120 Ksym/sec21000000 Hz54 dBmV
2015-10-3, 10:42:00
Critical (3)Resetting the cable modem due to docsDevResetNow
1970-1-1, 00:00:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:27Critical (3)No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:28Critical (3)No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:20Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=
1970-1-1, 00:00:30Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:30Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM--MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:33Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:40Notice (6)Honoring MDD; IP provisioning mode = IPv6
  • Upstream power is still too hot (ideally should be dropped by 6 dB if possible). I think someone at the ISP side need to reduce one of the attenuators in the upstream direction.
    are you facing any dropouts?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Chazz
    Looks like your ISP (most probably comcast) has enabled something called "Extended Upstream Power" on your account (which is good thing).
    Knowing that your Cable modem literally need to transmit at such high power, it is probably because you have too many splitters in your home or you have too much attenuation in your RF line coming into your home
  • Thanks for reply.
    I have one splitter in a bedroom with a power supply feeding it. I call it a wall wart. There may be one more splitter at the box outside.
    Would it be worth eliminating the one outside and I believe I don't need it anyway. To get a quicker or smoother connection?
    • vkdelta's avatar
      vkdelta
      yeah, better to eliminate spliters you really dont need.
      are you mixing Satellite (direcTV, Dish, etc) and Cable connections in your home? I guess now. Most people who have outside splitter, they have Internet from Cable company and TV service from satellite guy. OR sometimes it is just something old owner put that in.
      • Chazz's avatar
        Chazz
        Tutor
        No, comcast for tv and internet. im getting a diagram together so ill know how the wire runs and what splitters are there. I know its a littlke jacked up cause they were in a hurry. The installers didnt know ive been a low voltage tech for 20+ years lmao. Will get back to you on counts.
  • No been up and running fine getting 90 down and 12 up. I have eliminated coax or splitters in house. Has to be on pole, am I correct?
