- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi disconnection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi disconnection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi disconnection
Please visit and post about this over in the Cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same problem. Do you have on the Netgear Armor? Shut it off, worked for me
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the C7000 support Armor?
Doesn't look like it:
Which products support NETGEAR Armor? | Answer | NETGEAR Support
This place is getting horribly confusing with those content free "go away" messages:
Wifi disconnection - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Gdurney wrote:
Hello all. For about the past 2 months my modem/router has lost connection/restarted itself every night. The problem has gotten progressively worse as now it does it between 5-10 times a night sometimes. I contacted XFinity who advised they are not having any issues on their end or in my area. I’m curious if this is related to my modem/router?
Sounds likely.
Be warned that ISPs are great at passing the buck. There routine response is "blame the modem".
If you can catch the attention of @plemans, they know more than most about cable modems.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got a screen snip of your cable connections page and your event logs from the modem?
That helps check the line. Xfinity is great at their default response being "our line is fine"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
usually I tell people to remove any splitters/signal attenuators. In your case, try adding one in. Your power levels are high and that can cause issues.
Try putting a triple splitter or signal attenuator in the coax line. (use good quality cable/splitter).
then try using it and getting those pages again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This I can agree with. I printed out the entire manual for my device (AX6 AX 2700 Model CAX30) which is 132 pages long of information I would not otherwise have. After trying and changing every possible concivable problem I am convinced the main problem is the ISP and acutally do to the problem I'm having I'm surprised my device works at all. When I check my cable connection it always shows my ISP address and DNS as 0.0.0.0. I am getting a Dynamic IP adress for them otherwise I would make a static address. My modem/router was activated by them and myself on 3 seperate occasions and now thier app doesn't even give me the option to activate equipment anymore. It's suspcious to say the least. I have noticed that the disconnects come when the device is busy doing something, im guessing trying to obtain an IP and DNS address because of the 0.0.0.0 (or a new device was being scanned by armor). See if you can download the manual and follow the Trouble shooter chapter. My guess is your probably going to see the same thing "0.0.0.0"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What changes did you make?
Did you rerun the screen snip of the cable connections page and logs? with as many as you had, we should see shortly how good the connection is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
got a triple or quad splitter instead of a double?
To high of power can cause reboots/issues
