WhoCares_'s avatar
WhoCares_
Mentor
Sep 23, 2012
OwnCloud 8.0.3
ownCloud Community Edition
    • Description
      ownCloud is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud provides the ability to put the right files at the user's fingertips on any device in one simple-to-use, secure, private and controlled solution.
    • Requirements:
        • ReadyNAS Platform: Sparc
      • ReadyNAS Firmware: RAIDiator 4.1.8 or newer
    • Requires:
      • PHP 5.3: For this add-on to work, the PHP 5.3 add-on has to be installed first!
  • Configuration
    After installation of the add-on, open the add-on's pane from the list of installed add-ons and click on the "Access you ownCloud" link. You will be redirected to your ownCloud installation.
    if you're asked to login, use admin as your username. The default password after initial installation is netgear1.
    For further configuration options please consult the OwnCloud Online Documentation.
  • Updated to version 6.0.0a. Please note that OwnCloud puts a lot of load on Sparc based ReadyNAS systems and thus won't be really snappy or even fast.
  • Updated to version 6.0.1.
  • Updated to version 6.0.3.
  • Updated to version 6.0.4.
  • Updated to version 7.0.2.
    Added function to edit OwnCloud's config from within Frontview.
  • Updated to version 7.0.3.
    Added global share "RNXconfig" which allows for editing OwnCloud's config and install apps for OwnCloud.
  • Updated to version 8.0.0.
  • Updated to version 8.0.2.
  • Updated to version 8.0.3.
ProSupport for Business
