× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Problems while creating the .config for 3.12.43 Kernel in ReadyNASOS 6.3.5 (for comp. USB Modules)
it-guru
I am running 6.3.5 on my ReadyNAS Ultra 2 Plus and all works fine. My Problem ist, i need to add the OneWire USB Modules to my system for a Home-Automation solution.
This was my approach to get my target:
I open ...
http://kb.netgear.com/app/answers/detail/a_id/2649/~/gpl-open-source-code-for-programmers
... and found for "ReadyNAS OS 6(ReadyNAS 200)" the download link...
http://www.downloads.netgear.com/files/GPL/ReadyNASOS_V6.3.5_WW_src.zip
... and unpack this zip in a /usr/src/ReadyNAS/ReadyNASOS directory.
In this zip i found two posible directories (linux-3.12.43-52.6 and linux-3.12.43-52.6-alpine), which are seems to be the correct kernel source for ReadyNASOS 6.3.5 . I use linux-3.12.43-52.6 and so i do ...
cd /usr/src/ReadyNAS/ReadyNASOS/linux-3.12.43-52.6
make distclean      # seems to work fine
make olddefconfig   # seems also to work fine
... an now i try at first to compile the hole kernel without any modifications or additional modules with (to check, if .config is correct created) ...
make
This takes a longer time (>30 minutes) and multiple files can be correct compiled and linked but then i get the message ...
CC drivers/pci/msi.o
CC drivers/pci/htirq.o
CC drivers/pci/ats.o
drivers/pci/ats.c: In function 'pci_enable_ats':
drivers/pci/ats.c:68:52: error: 'struct pci_dev' has no member named 'physfn'
struct pci_dev *pdev = dev->is_physfn ? dev : dev->physfn;
drivers/pci/ats.c:70:19: error: 'struct pci_dev' has no member named 'sriov'
mutex_lock(&pdev->sriov->lock);
drivers/pci/ats.c:78:21: error: 'struct pci_dev' has no member named 'sriov'
mutex_unlock(&pdev->sriov->lock);
drivers/pci/ats.c: In function 'pci_disable_ats':
drivers/pci/ats.c:117:52: error: 'struct pci_dev' has no member named 'physfn'
drivers/pci/ats.c:119:19: error: 'struct pci_dev' has no member named 'sriov'
drivers/pci/ats.c:123:21: error: 'struct pci_dev' has no member named 'sriov'
make[2]: *** [drivers/pci/ats.o] Error 1
make[1]: *** [drivers/pci] Error 2
make: *** [drivers] Error 2
All Steps are done direct on my ReadyNAS (no crosscompile). I (think) i have all necessary build dependencies installed (build-essential, libncurses5-dev). My surmise is, the creation of .config is not correct.
Where can i found/get the correct (and working) kernel .config for the 3.12.43 Kernel on ReadyNASOS 6.3.5 ???
BTW: Does anyone know, what are the difference between linux-3.12.43-52.6-alpine and linux-3.12.43-52.6 in the src zip-file and what is the purpose of the -alpine kernel?
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: Problems while creating the .config for 3.12.43 Kernel in ReadyNASOS 6.3.5 (for comp. USB Module
6.3.5 was released for the 200 series (alpine arm).
We have a newer kernel again in 6.4.0 beta.
Message 2 of 3
it-guru
OK, now i have installed ReadyNASOS-6.4.0-T147-x86_64.img an it seems to work good.
But now i could not find the sources for this image.
At http://kb.netgear.com/app/answers/detail/a_id/2649/~/gpl-open-source-code-for-programmers there is no source package for the 6.4.0-T147  image.
Where can i found the source package, in which the source for the kernel 4.1.7 is included? (and the the needed .config file for the kernel to compile modules)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3887 views
  • 0 kudos
  • 2 in conversation
Announcements
