× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Transmission 2.82 for ARM – FREE
ssurba
Guide
Hi Everyone,
this is my build of Transmission Bittorrent client for NETGEAR ReadyNAS Storage Systems based on ARM processor architecture (DUO v2, NV+ v2).
General notes:
• Release notes for Transmission you can read on Transmission developers site: https://trac.transmissionbt.com/wiki/Changes
• This package was tested with versions 5.3.3, 5.3.4, 5.3.7 of the RAIDiator firmware. It may work with other versions, however I would recommend upgrading firmware to the latest version (5.3.7).
• Only transmission-daemon, client tools and Web interface are included in this package.
• After installing you should be able to access web interface from your browser by the following URL: http://[ip_address_of_your_NAS]:9091.
• Transmission network share will be created after installation. Normally you should not need it, it provides access to Transmission configuration (settings.json) and some other special files.
• By default downloaded files are saved to /Media/Torrents. You may later change it in Transmission configuration.
• Your NAS should be connected to the Internet when you are installing this package. Otherwise you could experience delays while installing the add-on and installation process may end with error due to timeout. This error can be ignored, as the package should be installed successfully.
• Before installing this version please remove any other builds of Transmission (those not made by me). But you can keep previous version of my build, newer version should upgrade it.
Download it from my website: http://www.sergeysurba.com/projects/transmission
Please try and test it, comments and suggestions are welcome. Discussion thread is here: http://www.readynas.com/forum/viewtopic.php?f=36&t=68561
Happy ReadyNASing!
Sergey.
Message 1 of 3
ssurba
Guide
Re: Transmission 2.82 for ARM – FREE
Build version changes:
Version 0.06
Compiled with uTP support.
Version 0.05
Enabled watch directory, by default it is located in Transmission share - \transmission\watch-dir. Put your .torrent files in it to start downloading.
Version 0.04
Included transmission-cli and other client tools in the build. Some fixes to directory structure that might prevent original Media share to appear.
Version 0.03
Fixed stop.sh script to shutdown Transmission correctly and allow it to save changes to settings.json. (Thanks Gray75)
Version 0.02
Fixed FTP access problem with proftpd crash by setting correct permissions on /var/log, also moved Transmission log to /var/log/transmission/transmission.log. (Thanks Torry)
Added logrotate.d config for Transmission log files maintenance.
Put a link to Transmission's web interface URL on Add-on Manager page. The Add-on Manager page is automatically reconfigured on start of Transmission to reflect changes in IP address of the ReadyNAS and/or Transmission web interface port (9091 by default).
Version 0.01
Initial release.
Message 2 of 3
ssurba
Guide
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7500 views
  • 0 kudos
  • 1 in conversation
Announcements
