Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGN2200 no internet connection with different devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-15
12:33 PM
2014-01-15
12:33 PM
Hi everyone
I just bought a N300 Wireless DSL Modem Router - DGN2200 and I experience the problem, that I cannot access the internet with more than one device (currently online with my MacBook pro) at the time. My devices (MacBook Pro, MacBook Air, iPhone 4, HP EliteBook notebook and two Samsung S3 phones) connect to the router but not to the internet.
I managed to do the following settings which I hoped to be the right ones after reading through different threads in here.
Internet set up --> Internet IP Address: get dynamically from ISP
Domain Name Server Address: get automatically from ISP
NAT: enable
Router MAC Address: Use default Address
Wireless set up: --> Enable SSID Broadcast
Region: Europe (I'm living in Switzerland)
Channel: Auto
Mode: Up to 145 Mbps
Security Options: WPA2-PSK (AES) --> I tried WPA-PSK (TKIP) + WPA2-PSK (AES) but then the internet connection with my macbook pro got lost.
LAN Setup --> IP Address: 192.168.0.1
IP Subnet Mask 255.255.255.0
RIP Direction: Both ways
RIP Version: RIP_2B
Use Router as DHCP Server: Yes
Starting IP from 192.168.0.2 to 192.168.0.254
Do I have to change some other settings or what can I do to make it work?
Thanks! B
NAT: enable
Channel: Auto
RIP Version: RIP_2B
Thanks! B
Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-15
12:55 PM
2014-01-15
12:55 PM
Re: DGN2200 no internet connection with different devices
Did you try updating the firmware? Maybe that will solve those issues. Also if you update the firmware don't forget to reset the router.
Message 2 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
01:12 AM
2014-01-16
01:12 AM
Thanks for your answer!
Yes, I did try it with an update. No luck 😞
Message 3 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
01:45 AM
2014-01-16
01:45 AM
Hi
instead of choosing
Router MAC Address: Use default Address. Try to check the Use computer mac address and also verify the vpi and vci values
instead of choosing
Message 4 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
11:30 AM
2014-01-16
11:30 AM
Thanks a lot for your help. I'm not really familiar with all this vpi and vci stuff but i think this is for adsl connections. But i got a cable one (over the TV plug). However adsl settings are on vpi 8 and vci 35. Seems right for switzerland.
I'm running out of options 😞
Message 5 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:06 PM
2014-01-16
12:06 PM
Since You have a Cable connection and the DGN2200 device supports only DSL connection.
better for Your cable connection you can buy DGN2200v4.
Message 6 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:10 PM
2014-01-16
12:10 PM
Incase If u have the DGN2200v4 connect the Modem to the Port NO:4 and change the WAN settings on the netgear genie 🙂
Message 7 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:18 PM
2014-01-16
12:18 PM
So you guys suggest buying another router as this one is not supposed to work with a cable connection?
Message 8 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:22 PM
2014-01-16
12:22 PM
So you guys suggest to buy another router as this one wont work with my cable connection?
Message 9 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:24 PM
2014-01-16
12:24 PM
DGN2200 is a ADSL Modem+Router and its support only DSL connections. Incase If u have DGN2200v4 it will working with your cable Modem.
Message 10 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
12:32 PM
2014-01-16
12:32 PM
The DGN2200 which you have its a ADSL2 Modem+Router which supports DSL connection.
Incase if have the same model but the Version 4 it will be working with the cable modem.
Message 11 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
01:19 PM
2014-01-16
01:19 PM
Will do that! Thanks a lot guys!
Message 12 of 12
Announcements
