Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND4000 Scan to PDF with ReadyShare
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-24
05:45 PM
2013-02-24
05:45 PM
Hi
I have a DGND4000 with a multifunction printer hooked up to the USB (Brother MFC 260C). I have Netgear USB Control Centre installed and can successfully connect to the scan function on the printer and scan documents to BMP, TIFF, etc. However, I can't chose to scan to PDF, which is my main need. I believe this may be due to limitations in Windows 7's inbuilt scanning utility.
I have the Brother software which came with the printer installed. With this I can scan to PDF if the printer is attached to the USB port on my laptop. However, with the printer attached to the modem, I don't seem to be able to activate this functionality.
Any help in setting up ReadyShare scan so I can scan to PDF greatly appreciated.
Cheers
somalade
Cheers
somalade
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-24
06:01 PM
2013-02-24
06:01 PM
Re: DGND4000 Scan to PDF with ReadyShare
Brother Application is likely not to design to do that
Buying network ready printer will better option
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
08:16 PM
2014-01-16
08:16 PM
Hi Somalade, Did you have any issues getting the router to find the the Brother MFC- using the NETGEAR USB Control Center? If so what did you do?
I am using the DGND3700v2 Modem/Router and I cannot get the printer to show up in the USB Control Center
Message 3 of 3
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
