Orbi WiFi 7 RBE973
Reply
DGND3700v2 and a Synology NAS server
ajm5k6
Hello,
My name is Adam and I need some help. At the bottom is a TLDR to sum this up. Thanks for your patience. 😄
I used to have Netgear router/modem combo provided from Cox Cable (specifically the Northern Virginia Cox Cable). I believe it was a CGd3000 model router (I cannot confirm that at this time). I bought a Synology Diskstation 214se and was able to stream video from the device with ease. The router, my Xbox 360 and Play Station 3 could find the 214se with no hassle and I could watch whatever I wanted.
That router died a silent death in the middle of the night and I was given a new modern/router combo from Cox Cable a Cisco 3825. While I could navigate to the 214se via HTTP my devices could no longer stream video.
I took to the internet and found out that the Cisco 3825 doesn't get along well with synology things. SO I did some more research and found the pleasant and compatible Netgear DGND3700v2. At first I was able to see the 214se but now I can't and thats the problem. I can't find my 214se any way. Under the Netgear WebGUI and my devices (both sucessfully connected to the network) cannot find my 214se at all. On the from of the 214se I have all the appropriate greenlights and at the back of the modem that tell me there is at least a layer 2 connection but no progress beyond that. Any help or insight would be greatly appreciated.
Message 1 of 5
jmizoguchi
Virtuoso
Re: DGND3700v2 and a Synology NAS server
Wireless isolation feature on router GUI if wired and wireless communication issues
Also check gateway ip in the NAS setting is correct
Message 2 of 5
ajm5k6
First of all thank you for the quick response, but almost as soon as I posted it a thought crossed my mind. When I was able to find the Diskstation my Netgear router had a 192.168 network address. BUT it had to change that address when it found that the Cisco 3825 router/modem all read had those addresses locked up.
SO what I did was connect my 214se back to the cisco and I was able to navigate back to it. SO NOW I am going to change the IP on the 214se to match the Netgear DGND3700v2 network range and hopefully find it that way.
Message 3 of 5
ajm5k6
Figured it out. I was over thinking the problem. I got it all figured out.
Message 4 of 5
jmizoguchi
Virtuoso
Good.. Usually is
Enjoy 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5059 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
