- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New firmware with built in Torrent Client
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New firmware with built in Torrent Client
After a fresh reboot, with the 2.4 ghz wireless not coming up, I took a snapshot of the wla and wlg params. Then I ran your cron commands, did another param snapshot, still no 2.4 ghz. Then I did the Apply trick in the gui, immediately 2.4 ghz is working. Did another wla params snapshot, ran a diff (would be nice to have diff on the router 🙂 ) zero differences.
I may get in another reboot later, dump the ALL the params before and after doing the Apply in wireless settings to see what is changing.
I did come across this, which is curious, but don't know if it means anything.
< wla_auth_type=opensystem
> wlg_auth_type=automatic
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should have no trouble flashing back and forth from the Richud firmware back to the Netgear firmware. I've done that before, but have been solid on the Richud firmware for well over a year now. I'm currently running the newest Genie based firmware and the only issues I've had are in the last few posts. Nothing that couldn't be dealt with. One feature in the new Genie firmware has that I really like is the ability to set DHCP lease times. I run a WHS2011 server and found that with the Netgear default and not changeable lease time of 1 hour I was unable to do a bare metal restore using the DGND3700 router. This new Richud Genie based firmware fixes that for me and I'm very thankful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, managed a new reboot, and the only difference in params is probably due to the IP camera on the 2.4 ghz wireless
505c505
< lan_upnp_wfa_subc_num=1
> lan_upnp_wfa_subc_num=2
550c550
< upnp_portmap_entry=0
> upnp_portmap_entry=1
I did notice after the reboot, there were no files associated with wl0 in var, just
-rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap0 -rw-r--r-- 1 root root 69 Oct 30 00:00 wlver -rw-r--r-- 1 root root 108 Oct 30 00:00 wl1cap -rw-r--r-- 1 root root 5 Oct 30 00:00 wl1bands -rw-r--r-- 1 root root 214 Oct 30 00:00 wl1 -rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap1 After doing the Apply, we now have the following in /var -rw-r--r-- 1 root root 99 Nov 5 17:28 wl0cap -rw-r--r-- 1 root root 3 Nov 5 17:28 wl0bands -rw-r--r-- 1 root root 220 Nov 5 17:28 wl0 -rw-r--r-- 1 root root 3 Nov 5 17:28 wpa_cap0 -rw-r--r-- 1 root root 69 Nov 5 17:28 wlver -rw-r--r-- 1 root root 108 Nov 5 17:28 wl1cap -rw-r--r-- 1 root root 5 Nov 5 17:28 wl1bands -rw-r--r-- 1 root root 220 Nov 5 17:28 wl1 -rw-r--r-- 1 root root 3 Nov 5 17:28 wpa_cap1
So, a possible clue as to why 2.4 ghz is not set up at startup? Just need to find how these files are written to /var .....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@paulmcg thanks + interesting -
Loading the defaults won't do anything unless saved and then reboot. However I dont think thats the problem from what you said.
wlandconfigd executes some wlctl commands which populate /var when it runs. Should 'start' whatever is set enabled via wlg / wla_wlanstate=Enable. Even if it starts and crashes or whatnot I'd expect at least something to get put in /var. (strings /usr/sbin/wlanconfigd | grep wlctl)
Assuming you are happy that both wla and wlg are set Enabled, you could try setting this;
param set rcS_hook_2="pkill -SIGUSR1 wlanconfigd"
If that doesn't work on boot try setting instead rcS_hook_3 which runs a bit later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like I was wrong, the wl0 files are there in /var after a reboot, but the timestamp is a lot older so there are being created at a different stage than when the wl1 files are created, e.g.
-rw-r--r-- 1 root root 214 Jan 1 2003 wl0 -rw-r--r-- 1 root root 3 Jan 1 2003 wl0bands -rw-r--r-- 1 root root 99 Jan 1 2003 wl0cap -rw-r--r-- 1 root root 214 Oct 30 00:00 wl1 -rw-r--r-- 1 root root 5 Oct 30 00:00 wl1bands -rw-r--r-- 1 root root 108 Oct 30 00:00 wl1cap -rw-r--r-- 1 root root 69 Oct 30 00:00 wlver -rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap0 -rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap1
I tried both the rcS_hook_3 and rcS_hook_3 suggestions, but neither made a difference. However, I was able to get wl0 up by running "pkill -SIGUSR1 wlanconfigd" manually, so that's an improvement from having to use the GUI. Adding @reboot sleep 45;/usr/bin/pkill -SIGUSR1 wlanconfigd to cron did not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not in front of it now but, the clock sets to the build date at some point in startup script , see /etc/init.d/rcS , so presumably wl1 comes up after that and wl0 before. (wlanconfigd is started by acos_service, which is started by rcS, for a timeline. acos_service starts all their internal stuff.).
(The GUI just restarts wlanconfigd when you hit apply, if you look at the PIDS before and after you can see what gets killed/restarted.)
rcS_hook_3 runs right at end of startup , perhaps before whatever is causing the problem happens. Bit odd that.
I don't think @reboot works in (busybox) cron off top of my head. [btw. diff is in the firmware already.]
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/DSL-Modems-Routers/Porting-v3-NG-GENIE-FW-on-DGND3700v1/td-p/417053...
- Mark as New
- Bookmark
- Subscribe
- Permalink
A thousand apologies, I had a typo in my rcS_hook_3 param. I have just done a reboot with it set to the correct value, and the 2.4 ghz came up OK, although it didn't show up as available till after the 5.4 ghz wireless.
I then removed the rcS_hook_3 param and tried it with the rcS_hook_2 param and it works as well, the 2.4 ghz wireless came up quickly, it was visible at the same time as the 5.4 ghz.
So, looks like something that works at last.
-rw-r--r-- 1 root root 220 Oct 30 00:00 wl0
-rw-r--r-- 1 root root 3 Oct 30 00:00 wl0bands -rw-r--r-- 1 root root 99 Oct 30 00:00 wl0cap -rw-r--r-- 1 root root 220 Oct 30 00:00 wl1 -rw-r--r-- 1 root root 5 Oct 30 00:00 wl1bands -rw-r--r-- 1 root root 108 Oct 30 00:00 wl1cap -rw-r--r-- 1 root root 69 Oct 30 00:00 wlver -rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap0 -rw-r--r-- 1 root root 3 Oct 30 00:00 wpa_cap1 drwxr-xr-x 2 root root 40 Jan 1 2000 zebra /tmp/var # param show rcS_hook_2 rcS_hook_2=/usr/bin/pkill -SIGUSR1 wlanconfigd
Perhaps you could add a 2.4 ghz specific level 2 param (set as"/usr/bin/pkill -SIGUSR1 wlanconfigd" - and saved) in /etc/init.d/rcS so the rcS_hook_2 param would still be available for testing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd like to ask you also to be sure before flash, does your "Original Version" firmware support VDSL with Annex A (Neostrada Fiber in Poland) and also Annex B ?
I can't decide which firmware will better option for me orginal one or Genie version, which one you think is more stable and polished.
I do not need any extra more option than I have now on orginal netgear firmware 1.0.0.17 only good working VDSL support.
Do you also confirm that I can always get back to orginal netgear firmware ?
I will be very appreciate for answers.
Also I'd like to thank very much "w3wilkes" for my answers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Peter: The new one, the DSL driver is newer and you should be able to swap versions without problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
r@ichud - thank you very much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://mega.nz/#!RVhXzKTK!KzrvrRIu_sCTqu8K_bFHVyENCY4gCTo44ohMPvecNcI
latest build from 3.0.0.22 source
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @richud
The new firmware loaded up very nicely, and the 2.4 Ghz came up OK, then I realised that I still had the rcS_hook_2 param set, so I removed that and rebooted.
After 5 minutes, no 2.4 Ghz, so I manually ran the "pkill -SIGUSR1 wlanconfigd" command and its all good. I will leave the rcS_hook_2 set up for the moment.
Apart from that, everything looks good from what I can see, all my settings, TZ, etc seem to be there.
Cheers, and thanks for all your efforts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, it's up and running. Still had to click Apply in Wireless after the load to get the 2.4Ghz radio to wake up. The boss says I don't have time to try another boot. 😉 Using Chrome on Win10 I need to set zoom at 90% to be able to see all items in Advanced -> Advanced Setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anywho, have added the signal to startup (rcS) where hook_2 is, so should solve problem without needing to add anything.
Have also rejigged menu so until w3wilkes gets himself a new 24" monitor for Christmas, he can see the menu! (hopefully)
https://mega.nz/#!UERw2byB!nktRkWxx0fFcC8o47yEqgUtM2xXBiYVr5pi4XYmpHEQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for this, the 2.4 ghz came up without issue (and I remembered to remove the rcS_hook_2 param before upgrading).
Still having an issue with the port forwarding display, the one that I created using the gui is not visible in the gui, I see it in the nat5 agApi_natDumpRuleTbl, but not in the inbound or pf_ params.
Really happy with the new Genie firmware. I will try and experiment with using the router as a VPN client soon, that would be great for Australia with the new fascist data retention laws.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Funny, I was fine once I figured out why I couldn't find those last couple of items in the Advanced setup. Set Chrome to 90% and it works fine. Chrome remembers to use 90% whenever I log in to the router so it's all good! Thanks so much for the work!
- Mark as New
- Bookmark
- Subscribe
- Permalink
(not in front of it now for exact names , but) I added some agApi dumps under in the 'Administration - Logs' > Network logs page thing, they should show the PF rules and uPnP rules, they have different id codes in the tables. [I haven't touched the PF or uPnP at all from stock firmware]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can anyone tell me whether this new firmware does Port Translation? For those that don't know that's Port Forwarding, but it allows receiving an external connection on port x but passing it on to an internal IP address on port y.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got this loaded up first thing this morning while I had some "king time". I set my zoom back to 100% just to check out what you did with the Advanced Setup. I like the way you've split it into two sections with the first having the original items and the second having your enhancements. And yes, the 2.4Ghz came up with the router.
Thanks very much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's something odd with DHCP lease times. After booting the router and then my PC here's what the PC shows in IPCONFIG
IPv4 Address. . . . . . . . . . . : 192.168.0.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, November 10, 2015 08:58:59
Lease Expires . . . . . . . . . . : Wednesday, November 11, 2015 08:58:56
This is a reserved IP with 24hrs set for reserved so the PC shows the correct info.
Here's what the router shows for this PC (I removed the MAC and Client ID). Since the PC shows correct I'm guessing the router must be mistaken on when the lease expires since it's in the past!
Lease expires MAC Address IP Address Hostname |
Tue 10/Nov/15 00:22 nn:nn:nn:nn:nn 192.168.0.3 W3-HP-Laptop |
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem is that the date / time is incorrect in the router. It's about 30 hours ago which seems rather strange. If I click apply or apply and commit in the Genie GUI in the Timezone Locale it does not correct. I use timezone of GMT -7:00 Mountain Time US and Canada.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just a question. Shouldn't the router get the time from the internet when it powers up? The only way I could get the time correct was to do a manual "date 111016442015" or "ntpd -q -p time.nist.gov".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really, can no one testing this just look at the port forwarding page and see if it's setup to do port translation?
Here's my original question: "Can anyone tell me whether this new firmware does Port Translation? For those that don't know that's Port Forwarding, but it allows receiving an external connection on port x but passing it on to an internal IP address on port y."
