- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up D6000 router with Epson Scanner
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear router installed which replaces a Linksys router on which the following worked connected via WPS to an Epson 235 Scanner/printer via wifi WPS.
Pressing the WPS/Reset on the Netgear Router makes the WPS light flash intermittently on the top of the router but when pressing the appropriate buttons on the Epson scanner - no connection is made and it isn't 'found'.
Anyone able to help?
Also - the Epson can be set up using a Pin Code - which I have.... Can the Netgear be setup to connect via wifi via Pin Code and if so how?
Thanks for any help...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting up D6000 router with Epson Scanner
Hello Neil23
Page 66 shows how to use the Pin method
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Darren
tried the PIN Code and the Epson s235 still doesn't get found by the Router....
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
