Orbi WiFi 7 RBE973
Reply
netgear wireless n 150
rostmus
Tutor
Buongiorno, attualmente con una connessione modem via cavo a Pc, su linea adsl, ho problemi di connessione. Il modem è un modello molto vecchio fornito dal gestore telefonicO. PER NECESSITA' di lavoro ho bisogno di una connessione. Un amico potrebbe prestarmi un wireless n 150 router. La mia domanda:
PUò funzionare come MODEM una volta collegato via cavo all' Adsl da una parte e, dall'altra al pc windows con un cavo ethernet di rete.?
Ringrazio anticipatamente chi può darmi una rispsta o un consiglio.
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: netgear wireless n 150
GT> [...] With this modem connected to my ADSL cable line I was unable
GT> to access a corporate network via the internet with which I have to
GT> work. [...]
   "non riuscivo" is not a helpful description of that problem.  It does
not say what you did.  It does not say what happened when you did it.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.  (Especially in Italian.)
> [...] Netgear wireless- n 150 router [...]
> _Which_ "a wireless n 150 router"?  "N150" is a speed, not a model
> number.
   Still a mystery.  Look at the product label.
   Without an actual model number, I don't know what you can do with
your "Netgear wireless- n 150 router".  If it's a router, then you might
be able to connect it to your old DSL modem.  (I also know nothing about
that modem.)
Message 4 of 4
All Replies
antinode
Guru
GT> [...] currently with a cable modem connection to a PC, on an ADSL
GT> line, I have connection problems. [...]
   "connection problems"?
GT> The modem is a very old model provided by the telephone operator.
GT> [...]
   _Which_ "very old model"?  Maker?  Model number?
GT> A friend could lend me a wireless n 150 router.
number.
GT> It can work as a MODEM [...]
   A modem is a modem.  A router is a router.  A modem+router is a
modem+router.  A router is not a modem.
   It might help if you provided some actual information about your
equipment and your "connection problems".
Message 2 of 4
rostmus
Tutor
Hi antidote, sto facendo attualmente hotspot per connettermi a Internet con un Picci Windows. Il collegamento tramite Hot Spot mi causa difficoltà a caricare nel browser del PC documenti ad esempio PDF di grandi dimensioni ed inoltre ogni tanto mi dà problemi di stabilità della connessione. Prima di trovare questa soluzione ho utilizzato un modem di Telecom Italia per : Alice Gate modulo base prodotto da Pirelli Broadband Solutions spa. Numero di targa Sap 1510 33 501. Con questo modem collegato alla mia linea ADSL via cavo non riuscivo ad accedere a una rete aziendale tramite internet con la quale devo lavorare. A questo punto ho ho provato a connettermi ad internet con lo stesso PC facendo hot Spot da un dispositivo cellulare. Successivamente parlando con un amico so che mi può prestare temporaneamente un Netgear wireless- n 150 router. Essendo poco pratico della materia ho rivolto alla community la domanda: Netgear wireless- en 150 router di cui non so se sia solo router o anche modem router potrebbe essere connesso via cavo o anche in altro modo alla mia linea ADSL e dall'altra parte al mio ingresso di rete del PC, procurandomi una connessione Internet più stabile del Hot Spot. Allego foto del mio " vecchio modem" grazie a chi vorrà darmi una risposta
Message 3 of 4
antinode
Guru
GT> work. [...]
> number.
that modem.)
Message 4 of 4
Discussion stats
  • 3 replies
  • 971 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
