Orbi WiFi 7 RBE973
Reply
Readyshare usb printer stopped
FRAN52
was working   security bulletin said there may be a problen  utility stopped ever since with no fix listed    WTF ????
Message 1 of 11
DarrenM
Sr. NETGEAR Moderator
Re: Readyshare usb printer stopped
Hello Fran52
What is model number of the product you have and can you give a little more detail on what happened and what you have tried to fix the issue.
DarrenM
Message 2 of 11
FRAN52
WNDR4500v2   readyshare print 1.36   error " a referral was returned from the server "
Message 3 of 11
FRAN52
checked firmware
reset router , printer, checked connections
uninstalled / reinstalled readyshare 1.36
no luck
Message 4 of 11
DarrenM
Hello FRAN52
What Operating system is your PC running?
DarrenM
Message 5 of 11
FRAN52
win 10 64bit
Message 6 of 11
DarrenM
Hello FRAN52
Have you tried to run readyshare print as admin or even try compatibility mode as windows 7?
DarrenM
Message 7 of 11
FRAN52
Yes   ACL administrator
I  suspect Norton Security has blacklisted readyshare
Message 8 of 11
FRAN52
it has been another month with not solution
when ic Netgear going to do something???
Do I need to look for another router / company?
Message 9 of 11
DarrenM
Hello Fran52
I thought you found that Norton was causing the issue. Has the error changed?
DarrenM
Message 10 of 11
FRAN52
Norton claims they are not blocking Readyshare.  When I shut them off, nothing works.
MS thinks its the driver.  I am on Win10 64bit and the driver thinks its a 32bit driver.
I cannot get a straight answer from anyone.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3554 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
