Orbi WiFi 7 RBE973
can you still use WEP key?
Melsmeeusen
Hello people,
I was wondering if it is still possible to use a WEP key. I want to go online with my nintendo DSI for the fun, but you need to have a WEP key, otherwise it can't get on your WIFI-router. So I looked at the routerlogin, but wasn't able to find a WEP key or make one.
So is it still possible or can't I go online anymore...?:'(
p.s.
They couldn't find my model. It's a WNDR3700v3 from Netgear.
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: can you still use WEP key?
choose 54 as mode then it should be listed
then setup guest using WEP and main using WPA2 or WPA  The link rate will be 54 on both
Message 4 of 4
All Replies
VE6CGX
Master
Of course if router has a setting for that.. Better than no security at all, LOL!
Message 2 of 4
Melsmeeusen
And do you maybe know where I could find this setting? because right now I can only choose between:
- none
- WPA-PSK (TKIP)
- WPA2-PSK [AES]
- WPA-PSL [TKIP] + WPA2-PSK [AES]
Is there maybe a setting I need to turn on first, before I can use WEP?
And would it also be possible to have a WPA and WEP key password at the same time?
I could also take off the password, but yeah, I'd like to have some kind of protection! haha
Message 3 of 4
Retired_Member
Not applicable
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8646 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
