justme0101's avatar
justme0101
no longer support 802.11 ac
when I first got the router it had phenomenal speed supporting 802.11 ac. now that the new firmware v2.02.08 has installed the router no longer sports 802.11 ac and the gui has changed taking away some features. the site is not letting me state the model number so here it is 600n c3700-100nas
  • StephenB's avatar
    The C3700 is a 802.11n gateway (the N600 means it supports max link speeds of 300 mbits in each band, and the throughput will be much lower than this).  It does not support 802.11ac  By current standards it is a low-end model.
    What speeds were you seeing before, and what speeds are you seeing now?
    • justme0101's avatar
      justme0101
      at first activation i was seeing 106 Mbps down and 6 Mbps up. Now its 49 Mbps down and 6 Mbps up. The only thing i can think of is the new firmware no longer supports the 802.11 ac. when I log on to the router wireless settings it shows the 2.4ghz  band supporting a,b,g,n and the 5 ghz supporting a/n. the router does or did at one point here is the link on the tech specs http://www.netgear.com/home/products/networking/cable-modems-routers/C3700.aspx#tab-techspecs
      • netwrks's avatar
        netwrks
        Master
        As StephenB indicated, your router has never supported. AC, only .N. From the link you posted. That is a far cry from  .AC.
        N600 WiFi Cable Modem Router
        802.11n Dual-Band Gigabit  - N600 (300 Mbps + 300 Mbps)‡
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    justme0101 I apologize for any inconvenience this may have caused you. It's true that the C3700 never supported 802.11ac, I already forwarded it to our web team to fix it.
