- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FVS318G VPN failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a FSV318G for years. I'm using shrewsoft VPN client to to connect to it from multiple locations and its worked for months and months with no problems until last thursday... Now I can't connect to the VPN router from any client.
Shrewsoft client output:
config loaded for site 'office.vpn'
attached to key daemon ...
peer configured
iskamp proposal configured
esp proposal configured
client configured
local id configured
remote id configured
pre-shared key configured
bringing up tunnel ...
network device configured
tunnel enabled
negotiation timout occurred
tunnel disabled
detached from key daemon
Which usually indicates that phase one completes. But the router VPN logs:
2015 Oct 28 12:24:41 [FVS318g] [IKE] Phase 1 negotiation failed due to time up for 17.58.98.236[500]. 7dbe94b6e00a6439:1152eb82ad35cc99_
2015 Oct 28 12:23:41 [FVS318g] [IKE] Setting DPD Vendor ID_
2015 Oct 28 12:23:40 [FVS318g] [IKE] For 17.58.98.236[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02_
2015 Oct 28 12:23:40 [FVS318g] [IKE] Received Vendor ID: CISCO-UNITY_
- Last output repeated 5 times -
2015 Oct 28 12:23:40 [FVS318g] [IKE] Received unknown Vendor ID_
2015 Oct 28 12:23:40 [FVS318g] [IKE] Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02__
- Last output repeated twice -
2015 Oct 28 12:23:40 [FVS318g] [IKE] Beginning Aggressive mode._
2015 Oct 28 12:23:40 [FVS318g] [IKE] Received request for new phase 1 negotiation: 10.1.10.191[500]<=>17.58.98.236[500]_
2015 Oct 28 12:23:40 [FVS318g] [IKE] Remote configuration for identifier "pb.local" found_
There is a cable modem router in front of the FVS318G buts its been there all along.
Help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, it goes back to the ISP router. It was either "bridged" like I said, or they had the 318 in the ISP router DMZ and were forwarding the ports to the 318 (not the ideal setup).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: FVS318G VPN failure
Does the 318 have a public IP on it's WAN? Check in the setup.
Do you have a static IP?
Are you using DynDNS?
Who is the ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the 316 does NOT have a public IP.
The facility does NOT have a static IP but the dynamic public IP has NOT changed in months
yes we are using dyndns.
the ISP is comcast.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They you have found your problem.
The 318 needs a public IP on its WAN..
The ISP probably updated the firmware on the cable modem and deleted/defaulted the previous settings.
The cable modem needs to be placed in Bridge Mode so that it passes the public IP to the 318.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cant test that solution until next week because the cable modem and router will be in constant use. But im skeptical, the settings on the cable modem haven't changed: it was never in bridge mode and the netgear Firewall VPN never had a public IP address. Is there another possible reason the VPN has suddenly failed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Comcast cable modem/router is now in bridge mode. The FVS318G has been assigned a static IP address. All users have access to internet . An RDC port is oped to a specific PC as test to make sure IP address is accessible. VPN still down: VPN client connects, tunnel is enabled but eventually times out. Suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
rebuilt the vpn policy ... all is good now
