OldPCGuy's avatar
OldPCGuy
FVS318G v2 Basic Setup Question
My ISP upgraded/switched me from a cable modem to a Gateway.  Now I can't use the FVS318 WAN port and FW, I have to use a LAN port essentially turning the firewall into an expensive switch.
I managed to put my Gateway in Bridge Mode.  when I logged into the FVS318 GUI it showed the WAN port and subnet all zeros.  I tried the auto detect and got no results.  It is almost as if the Gateway port did not activate in Bridge Mode.
Is the FVS318G plug and play where I just need to put the Gateway in Bridge Mode and that is it?   Should I see the Gateway address as 10.0.0.1 the same not in Bridge mode?  Do I need to configure anything on the FVS318 side?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi OldPCGuy,
    Welcome to the community! :)
    Kindly check this article and this might help you to verify if the gateway is properly set to bridge mode.
    DaneA
    NETGEAR Community Team
    • The Gateway is in bridge mode; network is up; I have access to the internet; but....
      I can't access the FVS318 GUI/Web page 192.168.1.1.  I also can't acces the Gateway GUI/Web page 10.0.0.1.  When I make a couple attempts I loose the internet connection as if somthing times out and drops the connection entirely.
      And the only way I can get the gateway and FVS318 to talk is to turn on the FVS first and let is assign IP's to all the network devices then turn on the Gateway; wait 15-20 minutes then the internet connection is back.
      Frustrating; this FW should be plug and play as a simple router.
      • OldPCGuy's avatar
        OldPCGuy
        OK I stand corrected. GUI/web pages are now accessible for both the Gateway, and FVS318 FW. I'm not used to modems and routers taking so long to do their thing. :(
ProSupport for Business
