Orbi WiFi 7 RBE973
Reply
FVS336g V3 wrong firmware
m1k3y02
Follower
Hi,
I upgraded firmware of my FVS336G V3 with the latest version for V1. I can't connect. DHCP doesn't assign IP, manual configuration does help so the factory reset.
Is there any hope for my device?
Thanks a ton!
Message 1 of 3
slowpoke338
Re: FVS336g V3 wrong firmware
Have you tried going back to the firmware that worked?
Message 2 of 3
ErikO
NETGEAR Moderator
Hello,
I would be very surprised if there is any way to recover the situation. The equipment would typically not even let you try an upgrade with an incorrect version, so if the FW upgrade went through it is probably a lost cause.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 503 views
  • 0 kudos
  • 3 in conversation
Announcements
