tsuihugh
Jun 05, 2022Follower
IPSec site to site VPN BR200 Access devices
site to site was configure wth ipsec vpn between br200
ping to other network go well
but the pc is denied access to other networks
i can not connect to ther server service(http, samba,.. etc) of another network
connect state is green and my firmware version 5.10.0.5
ipsec vpn configure is complete(remote route, remote subnet, remote subnet mask.. local subnet.. local subnet mask and ikev2 set , other option is default )
what settings should be added?
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
Kindly access the article below and use it as your guide for your BR200:
How do I set up a site-to-site IPSec VPN on my NETGEAR BR500 Business Router?
DaneA
NETGEAR Community Team
- gtoharpoonAspirant
I have a Br200 with the same problem. The IPsec VPN established and the status is 'green'.
I can ping the remote devices from both sides. However, I cannot access the services from both sides. No matter I set the static route or traffic rule.
What should I do of the correct router setting?
Thanks.
Since the IPsec VPN established wherein it shows that the status is 'green' and you can ping the remote devices from both sides, I think there is no problem on the VPN settings of the BR200. Kindly check the permissions set on the devices that you wanted to access.
Also, if ever you are not yet aware, kindly read the article below:
Security Advisory for Multiple Security Vulnerabilities on BR200 and BR500, PSV-2021-0286
DaneA
