- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ike phase 2 no end
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ike phase 2 no end
Hi:
I´ve a VPN working, but a pc don´t work. The same version SO (W10pro64), the same client (pro 6.40.004), the same imported configuration, firewall off, ports 500 and 4500 TCP open ...
Can someone help me plese? Thanks
20170516 12:07:09:321 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) is opening.
20170516 12:07:10:373 Default (SA Ikev1Gateway-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID]
20170516 12:07:11:019 Default (SA Ikev1Gateway-P1) RECV phase 1 Aggressive Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [NAT_D] [NAT_D] [VID] [VID] [VID] [VID]
20170516 12:07:11:029 Default (SA Ikev1Gateway-P1) SEND phase 1 Aggressive Mode [HASH] [NAT_D] [NAT_D]
20170516 12:07:11:031 Default phase 1 done: initiator id remote.com, responder id local.com
20170516 12:07:11:032 Default (SA Ikev1Gateway-P1) renewal in 3409 seconds (13:04:00)
20170516 12:07:11:117 Default (SA Ikev1Gateway-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20170516 12:07:11:118 Default (SA Ikev1Gateway-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20170516 12:07:11:213 Default (SA Ikev1Gateway-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20170516 12:07:11:214 Default (SA Ikev1Gateway-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20170516 12:07:11:216 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:16:215 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:21:230 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:26:231 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:31:234 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:36:237 Default (SA Ikev1Gateway-Ikev1Tunnel-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID]
20170516 12:07:36:237 Default transport_send_messages: giving up on message 01C623A8
20170516 12:07:37:266 Default (SA Ikev1Gateway-P1) SEND Informational [HASH] [DELETE]
20170516 12:07:37:267 Default <Ikev1Gateway-P1> deleted
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ike phase 2 no end
Hi Javier_AB,
Welcome to the community! 🙂
I'm not sure if you have already came across with these articles. However, let me share the articles below as reference guide:
ProSAFE VPN Client: Client to Box Configuration
Configure IPSec VPN Tunnels With the Wizard - read pages 8-15
Take note of the following:
a. Ensure that the local IP address of the PC (where the VPN Client Professional software is installed) is on a different LAN subnet than what is indicated on the LAN subnet of FVS318N. For example, if the existing LAN subnet of the FVS318N is on 192.168.1.x network, then the LAN IP address of the PC where you are using the VPN client Professional software should be on a different LAN subnet such 10.10.10.x or 192.168.9.x network.
b. You might need to disable the anti-virus or software firewall installed on the PC where the ProSAFE VPN Client Professional software is installed.
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DAneA:
Thanks for your interest
I´ll read this articles. The LAN address where is the FVS is 192.168.100.X and the client was tested at 192.168.1.X (and others). I know it must be a PC problem because others PC´s works fine with the exactly same configuration (W7 32b, W10 32b, W10 64) and "bad PC" was tested at diferent places
... will be continue
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just want to follow-up on this. Since the other PCs are working fine, then its possible that could be within the settings of the "bad PC" you are referring to that is not letting you connect. Are you the administrator of the "bad PC"? Also, were you able to read and tried the steps indicated on the articles I've shared to the "bad PC"?
DaneA
